Right, but in your BAQ for partmtl…You are linking the part table – correct? If you link partmtl company = part company and partmtl partnum = part partnum, you should be able to pull in part partdescription and part unit price for the partmtl partnum (since it matches the part partnum) – you can spot check if you don’t think this is correct…
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jdaniel1127@...
Sent: Tuesday, May 22, 2012 9:42 AM
Subject: Re: [Vantage] Re: Crystal report for Kits
part.list code is used for pricing ( i.e. in the us we sell it for a different price than europe so the same part number has 2 codes and prices... )
In the partmtl there is a parent part field that gives me the kit part number and the mtlpartnum is the sub part. Problem is getting the part description, listcode and price for the partmtl as they aren't in that table, they are in the part table...
----- Original Message -----
From: "Karen Schoenung" <kschoenung@...<mailto:kschoenung%40fisher-barton.com>>
Sent: Tuesday, May 22, 2012 10:15:52 AM
Subject: RE: [Vantage] Re: Crystal report for Kits
So you second BAQ has partmtl.partnum, part.partdescription, part.listcode?(not familiar with this field, maybe not in 803.409c), part.unitprice?
Then somehow you need to link the kit part to the partmtl in Crystal (not sure – we don’t use kits)
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> ] On Behalf Of jdaniel1127@...<mailto:jdaniel1127%40comcast.net>
Sent: Monday, May 21, 2012 4:22 PM
In my dashboard I have a BAQ with the Kit part, it's description, list code and price. With a filter of type='K'
The second BAQ in the dashboard pulls partmtl.partnum = part.partnum and haven't been successful linking the description list code or price for the partmtl.partnum...
From: "Karen Schoenung" < kschoenung@...<mailto:kschoenung%40fisher-barton.com> <mailto:kschoenung%40fisher-barton.com>>
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Monday, May 21, 2012 12:23:36 PM
In the dashboard, the BAQs can EACH link to the part table...So, your first BAQ has the KIT part and links to the part table, the second BAQ has the partmtl and links to the part table to get the description...
Then in Crystal, you need to make the links between the two BAQs as you require them...
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of b_ordway
Sent: Saturday, May 19, 2012 1:43 PM
Subject: [Vantage] Re: Crystal report for Kits
I would see if you can pull the descriptions from some other table.
Unfortunately I don't think 8.03 allows a second instance of the part table using an alias in a BAQ.
I switch over to an ODBC report sometimes when I run into this.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>, jdaniel1127@... wrote:
> I have the part.partnum and part.partdescription in the main crystal report for the kit part and trying to use a sub report for the partmtl to get the sub components in the kit. Is there a better way to do this??
> From: "b_ordway" <cooner_55421@...<mailto:cooner_55421@...<mailto:cooner_55421@...%3cmailto:cooner_55421@...<mailto:cooner_55421@...%3cmailto:cooner_55421@...%3cmailto:cooner_55421@...%3cmailto:cooner_55421@...>>>>
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Saturday, May 19, 2012 9:27:54 AM
> Â
> I usually link to the Part table if the description and group isn't already in the table I'm working with.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "jamesd" <jdaniel1127@> wrote:
> > Have a dashboard in Vantage 8.03.408B that displays the Kit part and the material parts with a filter by part, group or type. What I am trying to do is create a Crystal report from this so I can make a part catalog with part pictures. I have the parent kit part, description, group, price and .jpg in the crystal report and am trying to make a sub report for the kit components from the partmtl table. How do I get the description and group for these parts as they aren't in partmtl table?
> > Thanks,
> > James
