Crystal Report goes blank when field from newly added table is u
Vic,
I just wanted to say thank you. That worked! At least on the surface. I was ready to pull my hair out. I have another report I was having the same problem with. So now maybe I can fix it too!
Patricia Hall
Systems Analyst
Sent: Thursday, September 04, 2014 7:45 AM
Subject: RE: [Vantage] Re: Crystal Report goes blank when field from newly added table is used
Repeat the same joining/linking as you did in the RDD when you created the Relationship.
I'm not quite sure precisely what your ultimate goal is, but InvcDtl and ShipDtl are more suited for each other:  Company <-> Company ; OrderNum <-> OrderNum ; OrderLine <-> OrderLine ; OrderRelNum <-> OrderRelNum
Also, if you still can't get the linking to work, another option is to use the Linked Tables in the RDD instead of adding a table and relationship.  If you open ARForm in RDD Maintenance, click on the Report Table tab, then List, click on the InvcDtl table then click on the Linked Tables tab.  From here you can choose to add "linked tables" that Epicor already did all the heavy lifting for you.  Look for "Lookups" named PackLine (ShipDtl) and PackNum (ShipHead).  Once you add them, then you can add fields easily from the tables without creating a relationship.  The PackLine/PackNum fields will be embedded in the InvcDtl table.  Then in Crystal, you don't need to do any linking either.  Just look for your fields chosen in the InvcDtl table.
Sent: Wednesday, September 03, 2014 5:49 PM
Ok, I can do that. I know this sounds dumb, but if I delete all the links between my IncvHead table and my newly added table ShipDtl how will it link together?
Patricia Hall
Systems Analyst
[cid:image002.png@...7982E0]
3137 East 6th Street
Muscle Shoals, Al 35661
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
E: phall@...<mailto:phall@...>
www.cbcings.com
Sent: Wednesday, September 03, 2014 4:44 PM
You should be able to delete one link at a time. Click on the link and hit the delete button.
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Wednesday, September 03, 2014 2:28 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Ok, so if I select the link and click delete link will it delete all the links between the two tables? How can I select only the RptLanguageID link to delete it?
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
E: phall@...<mailto:phall@...<mailto:phall@...%3cmailto:phall@...>>
www.cbcings.com<http://www.cbcings.com>
Sent: Wednesday, September 03, 2014 4:07 PM
Check your links – sometimes you need to delete the link between RptLanguageID
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>> [mailto:vantage@yahoogroups.com]
Sent: Wednesday, September 03, 2014 12:21 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>>
I made the change in the join between InvcHead and ShipDtl to an outer join as suggested. My report doesn’t blank out now which is way better than I had. Thanks Jarrad! However, there’s still no data returned. I checked to make sure the field I need to add has data and it does.
Patrick, below is a shot of my linking. They appear to all be parent to child but I’m new at this so I’m not sure.
[cid:image001.jpg@01CFC782.447D1E00]
[cid:image002.jpg@01CFC782.447D1E00]
The relationship I made was:
[cid:image003.jpg@01CFC782.447D1E00]
The schema is a part of the xml but there’s no data showing in it. And yes, I agree, the whole process is hard to work with.
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
E: phall@...<mailto:phall@...<mailto:phall@...%3cmailto:phall@...<mailto:phall@...%3cmailto:phall@...%3cmailto:phall@...%3cmailto:phall@...>>>
www.cbcings.com<http://www.cbcings.com<http://www.cbcings.com%3chttp:/www.cbcings.com>>
Sent: Wednesday, September 03, 2014 1:55 PM
Subject: [Vantage] Re: Crystal Report goes blank when field from newly added table is used
I would check my linking inside of Crystal. menu path Database > Database expert > Linking tab.
try making the shipdtl table an outer link to see if your data appears
Added an additional table to an RDD that I have modified before. (Added ShipDtl table to the AR Form)
Added a new relationship (InvcHead to ShipDtl).
Created the xml and set the database location in Crystal.
New table appears in the field explorer.
Did a print preview and can see data in the report.
Problem is every time I try to add a field from the new table to my report the report goes blank and all data the was present during preview disappears.
The schema for the ShipDtl table is in the xml but there's no data.
Anyone have any suggestions? I've been fighting this for days. This also happened when I tried to add a table to the RMA Form. Couldn't get it to work either.
Any help would be greatly appreciated.
Patricia Hall
One thing to watch BAQs join Child to Parent, Crystal joins Parent to Child, so in crystal check the direction the link arrows are pointing and that all your joins are setup properly.
Patrick Winter
Sent: Wednesday, September 03, 2014 13:50
Subject: [Vantage] Crystal Report goes blank when field from newly added table is used
Patricia Hall
This email and any attached files are confidential and intended solely for the intended recipient(s). If you are not the named recipient you should not read, distribute, copy or alter this email. Any views or opinions expressed in this email are those of the author and do not represent those of the Specialty Screw Corporation company. Warning: Although precautions have been taken to make sure no viruses are present in this email, the company cannot accept responsibility for any loss or damage that arise from the use of this email or attachments.
If the schema is part of the xml but there's no data I'd say it might be a problem with the data definition relationship.  I've always found that whole process to be a bit temperamental.
But yes, also check the crystal report links to make sure it's a proper parent/child to invoice header as well as left outer join.
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
I'm not quite sure precisely what your ultimate goal is, but InvcDtl and ShipDtl are more suited for each other:Â Company <-> Company ; OrderNum <-> OrderNum ; OrderLine <-> OrderLine ; OrderRelNum <-> OrderRelNum
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
www.cbcings.com
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
