Crystal Report On Vantage 8.03 BD SQL Server 2005
Did you try adding another ODBC user with limited read only table
access and no password for that ODBC user?
--- In vantage@yahoogroups.com, "fnaslis" <fnaslis@...> wrote:
> Same thing, i also change the Use DSN Default Properties to TRUE in
> crystal report but the result is the same :(
> --- In vantage@yahoogroups.com, Bartosz Niemczewski
> <bartoszniemczewski@> wrote:
> > Did you try LogonID , too?
Hi all,
I'd like to add custom table on vantage existing report (Order
Acknowlegment), does someone know how to use the user sysprogress in
order to not having a user/ password prompt when opening the report.
Thanks in advance.
Fred.
Fred,
A custom table? Meaning a non-Vantage table within the database?
If it's simply another Vantage system table, you should be modifying the Report Data Definition to get your tables joined, not ODBC.
However, if you do, in fact, have a non-standard Vantage table that you've created within the Mfgsys803 database, then ODBC is your only option.
Go to www.connectionstrings.com and you should be able to find a connection string there. Use that in your Crystal Reports report instead of an ODBC DSN.
Hth.
Vic
Vic Drecchio
ERP Administrator
TIMCO Aviation Services
Greensboro, NC
Email:Â Â vic.drecchio@...
Office:Â 336.668.4410 x3091
Mobile:Â 704.530.3092
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of fnaslis
Sent: Friday, February 13, 2009 3:47 PM
Subject: [Vantage] Crystal Report On Vantage 8.03 BD SQL Server 2005
Hi all,
Thanks in advance.
Fred.
Thanks Vic,
That it i want to connect to other database, my point is taht i don't
want a login prompt as i got when i use a DSN.
Any Ideas ?
Maybe by use a RDO connectionstring property ?.
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
wrote:
> Fred,
ODBC.
option.
> Hth.
> Vic
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf Of fnaslis
> Hi all,
in
> Thanks in advance.
> Fred.
access. )
In Registry for your odbc connection add two string keys UserName and password, then set your values for that parameters .
Sent: Monday, February 16, 2009 10:34:16 AM
Subject: [Vantage] Re: Crystal Report On Vantage 8.03 BD SQL Server 2005
Thanks Vic,
Any Ideas ?
--- In vantage@yahoogroups .com, "Vic Drecchio" <vic.drecchio@ ...>
wrote:
> Fred,
ODBC.
option.
> Go to www.connectionstrin gs.com and you should be able to find a
> Hth.
> Vic
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
> Email:Â Â vic.drecchio@ ...
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf Of fnaslis
> To: vantage@yahoogroups .com
> Hi all,
> Acknowlegment) , does someone know how to use the user sysprogress
in
> Thanks in advance.
> Fred.
access. )
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Doesn't work either, also i add pwd and Uid and i m always prompt to
login :(
> From: fnaslis <fnaslis@...>
2005
> Thanks Vic,
don't
> Any Ideas ?
> wrote:
> > Fred,
> ODBC.
that
only
> option.
> > Hth.
> > Vic
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
On
> Behalf Of fnaslis
2005
> > Hi all,
sysprogress
> in
report.
> > Thanks in advance.
> > Fred.
> access. )
Sent: Monday, February 16, 2009 11:35:26 AM
login :(
--- In vantage@yahoogroups .com, Bartosz Niemczewski
> ____________ _________ _________ __
> From: fnaslis <fnaslis@... >
2005
> Thanks Vic,
don't
> Any Ideas ?
> wrote:
> > Fred,
> ODBC.
that
only
> option.
> > Hth.
> > Vic
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com]
On
> Behalf Of fnaslis
2005
> > Hi all,
sysprogress
> in
report.
> > Thanks in advance.
> > Fred.
> access. )
2005
to
> login :(
> > From: fnaslis <fnaslis@ >
Server
> 2005
> > Thanks Vic,
> don't
> > Any Ideas ?
<vic.drecchio@ ...>
> > wrote:
> > > Fred,
not
> > ODBC.
> that
> only
> > option.
a
> > > Hth.
> > > Vic
> > > Vic Drecchio
> > > ERP Administrator
> > > Greensboro, NC
yahoogroups .com]
> On
> > Behalf Of fnaslis
> 2005
> > > Hi all,
> sysprogress
> > in
> report.
> > > Thanks in advance.
> > > Fred.
You
enable
> > access. )
goto:
Yes, Fred, in your database setup on the Crystal Reports report, use a connection string. Visit www.connectionstrings.com for a comprehensive list of connection strings to use.
Sent: Monday, February 16, 2009 11:34 AM
Thanks Vic,
Any Ideas ?
wrote:
> Fred,
ODBC.
option.
> Hth.
> Vic
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf Of fnaslis
> Hi all,
in
> Thanks in advance.
> Fred.
access. )
I already set a connectionstring and everything works fine in
Crystal , but i always got a login prompt when i load the report in
Vantage.
Behalf Of fnaslis
2005
> Thanks Vic,
don't
> Any Ideas ?
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@>
> wrote:
> > Fred,
> ODBC.
that
only
> option.
> > Hth.
> > Vic
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
> Behalf Of fnaslis
2005
> > Hi all,
> in
report.
> > Thanks in advance.
> > Fred.
> access. )
access. )
Have you populated the two fields on System Agent for ODBC Connection info?
Sent: Tuesday, February 17, 2009 8:45 AM
Vantage.
Behalf Of fnaslis
2005
> Thanks Vic,
don't
> Any Ideas ?
> wrote:
> > Fred,
> ODBC.
that
only
> option.
> > Hth.
> > Vic
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
> Behalf Of fnaslis
2005
> > Hi all,
> in
report.
> > Thanks in advance.
> > Fred.
> access. )
access. )
