Crystal Report .Rpt file deletion
Wow, interesting bug. How'd that one slip through the Quality dept?
Of David Beberman
Sent: Tuesday, December 29, 2009 12:08 PM
Subject: RE: [Vantage] Crystal Report .Rpt file deletion
This is a known issue to Epicor - sorry if I wasted anyones time,
"This has been reported as a bug. Development has issued an SCR (SCR #
61543). According to the SCR the fix was included in the 505 service
pack. If you have many custom Crystal Reports that you would like to add
to the menu, it is recommended to that you upgrade to the 505 service
pack and then apply the 505B patch to resolve this issue."
-Dave
Of David Beberman
Sent: Tuesday, December 29, 2009 12:00 PM
Subject: [Vantage] Crystal Report .Rpt file deletion
Hi all,
We have found an odd behavior when running a linked report (Crystal)
added to a menu.
Creating a report from development, we copy it to
\\(server)\epicor904\server\reports\CustomReports.
We can run the report exactly once, then the report is deleted upon
exiting the Crystal Viewer.
Setting the *.rpt to read-only proves the I/O command was issued by the
Epicor Crystal viewer to delete:
Error Detail
Access to the path
'\\Epicorsrv\epicor904\server\reports\CustomReports\FOBDumpNonBAQ.rpt'
is denied.
Stack Trace
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.Delete(String path)
at
Epicor.Mfg.Lib.Report.EpiCrystalViewer.OnFormClosed(FormClosedEventArgs
e)
Has anyone seen or experienced this behavior ?
David B
Programmer/Analyst
Ferguson Perforating
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Hi all,
added to a menu.
Error Detail
Access to the path
is denied.
Stack Trace
at
e)
David B
Programmer/Analyst
-Dave
Of David Beberman
Hi all,
added to a menu.
Error Detail
Access to the path
is denied.
Stack Trace
at
e)
David B
Programmer/Analyst
