Crystal Report Run from outside of MfgSys?
Logicity has a free viewer that's good and launches any RPT file (and allows the input of params, if used). And it can be installed in parallel with the Epicor CR Runtime on the same PC. It's worked for me in the past.
http://www.logicitysuite.com/products/logicity-pro/feature-comparison.html
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ckrusen1@...
Sent: Tuesday, February 18, 2014 3:59 PM
Subject: [Vantage] Crystal Report Run from outside of MfgSys ?
Is there a run time engine that would allow people to run Crystal ODBC reports without having to set them up as a menu item and be launched from within MfgSys?
I recall that the MfgSys client install process installs a CR runtime program (and often the "wrong" one for the clients O/S).  Can that be launched manually, and could it open and run CR's .RPT files?
Thanks in Advance.
Calvin
P.S. Running MfgSys 8.03.409C with Progress OE10.1B
Thanks in Advance.
Calvin
