Shirley,
The file you downloaded was the client install for workstations. This
file is used in all of our custom reports as well as the multi form utility.
The actual utility is installed on the server and is not available for
download from our web server. The setup package for the server install
contains all of the installation instructions.
If you have any other questions please contact me directly.
Mark Charamut
Managing Member
Caesar Development Services, LLC
mcharamut@...
(860) 225-0369
Mark Charamut
Managing Member
mcharamut@...
(860) 225-0369
----- Original Message -----
To: <vantage@egroups.com>
Sent: Monday, August 28, 2000 5:31 AM
Subject: RE: [Vantage] Crystal Report Utility
> Ok, I went to the suggested link downloaded the file and ran the install
on the client. There were no README's or other sorts of instruction. I went
to FAQ, no happiness there, I went to support, Nope not there either, screen
shots? nope. Is there some sort of text that will help get this utility to
run. I looked in all the obvious places but could locate anything that was
helpful. Any words of wisdom would be much appreciated.
> Shirley Graver
> Sys Admin
> Rubber Associates
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
