I went back to Crystal. The formula was first created in basic
syntax and when I checked the formula it came back ok. I changed to
crystal syntax and checked the formula and there was an error. I
fixed this, checked the syntax and it was ok, saved it and then went
back to Vantage and now the 515 error is gone. Thank you for the
info. I would still like to know how to add the PO Rel open field to
the report. Any help on that would be appreciated. TIA.
- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@c...>
wrote:
> This is what the Epicor AnswerBook says about error 515.returns
> 515 BADFORMULATEXT There is a formula error in the replacement
> formula text. Review the formula syntax and retry. This also
> the formula name and a formula message indicating the source of theto
> error.
> HTH,
> Brian Stenglein
> --- In vantage@yahoogroups.com, "Joanne Yargeau" <jyargeau@t...>
> wrote:
> > I created a formula field for the PO detail open line. If it was
> > true to print Open and false to print closed. Added this field
> > the report, saved it. Went to Vantage and got the error. Wentwrote:
> back
> > to Crystal set location, verify database and then resaved to
> another
> > name, back to Vanatage changed to resaved report and still error
> 515.
> > --- In vantage@yahoogroups.com, "Sherri Hill" <sherrih@g...>
> > > What type of change did you make to the Crystal Report thatthe
> caused
> > the
> > > 515 error?
> > > Sherri Hill
> > > Sr. Programmer Analyst, GBS
> > > 330-494-5330, Ext. #2405
> > > _____
> > > From: Joanne Yargeau [mailto:jyargeau@t...]
> > > Sent: Wednesday, June 23, 2004 9:00 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Re: Crystal Report Ver 8
> > > I have two questions for Crystal Reports. I made a change in
> > POfine
> > > Form and now I get the error 515. I can preview the report
> inYou
> > > Crystal but I get the error in Vantage. I also would like to
> know
> > > how to get the PO Rel Open line field on this form. It is not
> > > available on the dbf fields for selection. TIA.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > must<http://us.ard.yahoo.com/SIG=1298p7lvv/M=295196.4901138.6071305.300117
> > > have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > <http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/links
> > > Yahoo! Groups Sponsor
> > > ADVERTISEMENT
> > > click here
> > 6/D=groups/S=1705007183:HM/EXP=1088082028/A=2128215/R=0/SIG=10se96mf6/*h
> > ttsubject=Unsubscribe>
> > > p:/companion.yahoo.com>
> > > <http://us.adserver.yahoo.com/l?
> > M=295196.4901138.6071305.3001176/D=group
> > > s/S=:HM/A=2128215/rand=608383110>
> > > _____
> > > Yahoo! Groups Links
> > > * To visit your group on the web, go to:
> > > * To unsubscribe from this group, send an email to:
> > > vantage-unsubscribe@yahoogroups.com
> > > <mailto:vantage-unsubscribe@yahoogroups.com?
> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > > Service <http://docs.yahoo.com/info/terms/> .
