thanks @s1mhall i did install the 32bit and it worked well.
Sent: Tuesday, November 27, 2012 2:16 PM
Subject: [Vantage] Re: Crystal Reports 2010 SP3 Error on Epicor 9.05.701
Â
Hi,
Epicor provide the 32 bit version of the runtime as well as the 64 bit version. We got the same error when assuming that the 64 bit runtime needs to be installed on 64 bit operating systems.
We use mfgsys.exe not mfgsys64.exe. The bit version of the runtime I believe relates to the version of mfgsys not the operating system.
We have had success running the 32bit runtime on both 64 and 32 bit windows 7, provided we used mfgsys.exe.
We have also had success running Crystal 2008 SP3 developer on the same machine with no adverse results.
I hope that helps.
There are various messages on the SAP forums about this exact error, after reading a few they gave me the idea to try the runtime. In actual fact we even had instances where system monitor would report the report printed successfully but the crystal preview would not show and there were no errors output by the application.
Cheers
Simon Hall
Â
Hi,
I hope that helps.
Cheers
Simon Hall
--- In vantage@yahoogroups.com, Tony Karugu <tonykarugu@...> wrote:
> Hi Kent,
> I noticed this too and had it uninstalled on one of the new installs. The other new 701 installation i only installed the crystal report runtime 2010 SP3. Still the same results.
> thanks
> Anthony
> From: reardon_kent <k-reardon@...>
> Sent: Saturday, November 24, 2012 5:22 PM
> ÂÂ
> Don't know if you have a version of Crystal Developer on that same server, but if you do that's the problem. For some reason 701 won't let you run the two on the same server.
> --- In vantage@yahoogroups.com, Tony Karugu <tonykarugu@> wrote:
> > HiÂÂ
> > I have 2 new Installs on Epicor 9.05.701 and a Upgrade from
> > 9.05.700B to 701. I have followed all the steps for installing crystal
> > runtime as the documentation illustrates. But keep getting the error.  .Net Framework 4 is
> > installed already. What am I missing out? When I Screen Print no report
> > pops up, report is already run under System Monitor where now I Screen Print
> > again and get the error.
> > ÂÂ
> > ERROR
> > Error Detail
> > The type initializer for
> > 'CrystalDecisions.ReportSource.ReportSourceFactory' threw an exception.
> > ÂÂ
> > ÂÂ
> > Stack Trace
> >   at
> > CrystalDecisions.Windows.Forms.CrystalReportViewer..ctor()
> >   at
> > Epicor.Mfg.Lib.Report.EpiCrystalViewer.InitializeComponent()
> >   at
> > Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String reportTitle)
> >   at
> > Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String rptFile, String dataFile,
> > PrinterSettings printSettings, String reportTitle, List`1 rptDocList, Session
> > session)
> >   at Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String
> > rptFile, String dataFile, String reportTitle, List`1 rptDocList, Session
> > session)
> >   at
> > Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.previewCrystalReport()
> > ÂÂ
> > Inner Exception
> > 'CrystalDecisions.Shared.SharedUtils' threw an exception.
> > ÂÂ
> > Inner Stack Trace
> >   at
> > CrystalDecisions.Shared.SharedUtils.GetFullTypeName(Type type)
> >   at
> > CrystalDecisions.ReportSource.ReportSourceFactory..cctor()
> > ÂÂ
> > Inner Exception
> > Could not load file or
> > assembly 'log4net, Version=1.2.10.0, Culture=neutral,
> > PublicKeyToken=692fbea5521e1304' or one of its dependencies. The system cannot
> > find the file specified.
> > ÂÂ
> > Inner Stack Trace
> > ÂÂ
> > Regards
> > ÂÂ
> > Anthony
