Crystal Reports ActiveX Error
Ya, that is what they told me to do as well, unless I wanted to
spend the money to have their customer programming group look at it.
Keith
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...>
wrote:
> This was all they could offer me was to print preview it first
then print it
> from there.
> ~Charlie
> ________________________________________
Behalf Of
> khfsu82
> Sent: Monday, January 12, 2009 2:28 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Crystal Reports ActiveX Error
> Was the only feedback that you received from Vantage support to
run
> the report to print preview first and then print from the preview?
> Did they offer any other work arounds? I noticed that I began
> receiving the error when I added a conditionally suppressed
> subreport to the form. When I take it off, I do not get the
message.
> - Keith
> --- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@>
> wrote:
> > I have not seen anything come through as to a release of a fix
to
> this
> > problem. The only way I think they are going to be able to fix
> this one is
> > to release a new version of the runtime or a patch for the
current
> runtime.
> > Highly doubt that will be anytime soon.
> > ~Charlie
On
> Behalf Of
> > khfsu82
> > Sent: Monday, January 12, 2009 1:47 PM
> > Charlie,
> > Was there ever any resolution to this problem. We are having the
> > same issue as well.
> > Thanks,
> > Keith
<foamdesigncsw@>
> > wrote:
> > > All,
> > > A while back there was a short discussion about An ActiveX
error
> > that would
> > > pop up when you tried to print certain crystal reports since
> they
> > upgraded
> > > to the new runtime that works with .net 3.0.
> > > I got word from epicor on this problem:
> > > SCR 57714 has been issued for your "Object reference not set
to
> an
> > instance
> > > of an object" (no details) message from the Crystal Report
> Windows
> > Form
> > > Viewer.
> > > Development has duplicated this problem. As a workaround, you
> > should be
> > > able to preview the report, and then press the Print button.
> > > ~Charlie
All,
A while back there was a short discussion about An ActiveX error that would
pop up when you tried to print certain crystal reports since they upgraded
SCR 57714 has been issued for your "Object reference not set to an instance
of an object" (no details) message from the Crystal Report Windows Form
Viewer.
Development has duplicated this problem. As a workaround, you should be
~Charlie
Charlie,
same issue as well.
Keith
wrote:
> All,
that would
upgraded
instance
Form
> Viewer.
should be
> ~Charlie
I have not seen anything come through as to a release of a fix to this
problem. The only way I think they are going to be able to fix this one is
to release a new version of the runtime or a patch for the current runtime.
~Charlie
khfsu82
Charlie,
same issue as well.
Keith
wrote:
> All,
that would
upgraded
instance
Form
> Viewer.
should be
> ~Charlie
Was the only feedback that you received from Vantage support to run
subreport to the form. When I take it off, I do not get the message.
- Keith
this
this one is
runtime.
> ~Charlie
Behalf Of
> khfsu82
> Charlie,
> same issue as well.
> Thanks,
> Keith
> wrote:
> > All,
> that would
they
> upgraded
an
> instance
Windows
> Form
> > Viewer.
> should be
> > ~Charlie
This was all they could offer me was to print preview it first then print it
from there.
~Charlie
khfsu82
- Keith
this
this one is
runtime.
> ~Charlie
Behalf Of
> khfsu82
> Charlie,
> same issue as well.
> Thanks,
> Keith
> wrote:
> > All,
> that would
they
> upgraded
an
> instance
Windows
> Form
> > Viewer.
> should be
> > ~Charlie
