Crystal reports add field
Well, in Vantage 8, you can go to Company Maintenance and select the
"Report Data Definition". Find your report, (QuotForm) in this case.
Duplicate it under "Actions", as you don't want to edit a system report.
There you can click on the "Report Table" tab, and then click on the
"Excluded Fields" tab. Navigate the tree on the left and click on the
"QuoteDtl" table under "report Tables(7)". Find your field and click
the "<" arrow... Save it.
Then under "Company Maintenance", Open "Report Style". Open the
"QuotForm", and click the "Styles" tab. Under Datadefinition, select
the new QuotForm definition that you just created. Save it, and run
that report and that field should be in your XML file now.
--Matt
Of ofcwiz
Sent: Saturday, May 03, 2008 2:24 PM
Subject: [Vantage] Crystal reports add field
I would like to add to the QuoteForm.rpt a field from the QuoteDtl
table called SellingExpectedQty. When I lookup the table, I can see
the field availability but when I go to Crystal reports, it is not
available to add to the report. The table is a part of the report but
I cannot find a method to make the field available.
Anybody know if this can be done??
