Crystal Reports and 9.05.607
We get a similar error when some monkey writes a novel in a Comment field that should only hold 1,000 characters or they Cut/Paste from Outlook and you get funky formatting characters in the comment field.
I use a SQL Query to read the data from the table and keep adjusting the date field back a week until it works, then creep back on it and find the record that has the invalid data then fix. The report works fine after that.
Good Luck,
George Hicks
PCI
--- In vantage@yahoogroups.com, "dctechnologiesllc10" <dan@...> wrote:
> Any one ever run across an issue where you can get the custom crystal report to pull the data you want when previewing it in Crystal but when running it through Epicor getting the following Error: This group section cannot be printed because its condition field is nonexistent or invalid. format the section to choose another condition field. Error in File tmpC9A8{A6C8699C-9E03-424A-AEEB-A20CBF73FBF9}.rpt: Invalid group
> condition.
condition.
