Hello,
I customized Job Pick List report by adding barcodes for warehouse, bin and
lot.
The issue I am having related to bin for example made of 2 words, like BIN 09.
When barcode created in Crystal reports it makes barcode also made of 2
barcodes. And our handhelds don't read that. They only read when barcode is
shown as 1 barcode. How to make it as 1 instead of 2 in crystal reports. Thanks
Mike.
Do you have a complete formula for barcode 39 with the space?
Also what important, that:
After barcode is converted to 1 barcode, it should read back with handheld back to Epicor as 2 words,
like BIN 09, not BIN09.
Please let me now.
Mike
do you have a complete formula for the barcode 39 with space?
What important also:
1. BIN 09 is bin field.
2. It has to be coded as 1 barcode.
3. When read with handheld, it should read BIN 09, not BIN09, so Epicor can recognize it.
Please let me know.
Mike
Add a * at the beginning and end..... everything in between is treated as the actual barcode data, including spaces.
The example below is a barcode I use for labour capture, ie MES. The job number is scanned then the bar code example below..... $I is a tab and $M is an enter. I actually had the job number in there as well but found under certain circumstances the operation sequence was dropping digits based on timing (possible server speed at scan time etc).
"*" & totext({JobAsmbl.AssemblySeq},0,"") & '$I' & totext({JobOper.OprSeq},0,"") & '$I' & '$I' & '$I' & '$I' & '$M' & "*"
This is using simple Symbol usb barcode readers (configuration required)
"*"& replace({table.field}," ","_")&"*"
It creates 1 barcode, but when scanned by handheld, it show *BIN_09*
Mike
You can also try replacing the space with an equal sign.
Go to an online barcode generator an make an image for a barcode containing a space, and see how your scanner interprets it.
