Crystal Reports - barcodes scan with and without decimals
Vic,
This worked for us - we have now changed a couple of reports and labels based on this.
Thank you,
Karen
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karen Schoenung
Sent: Wednesday, February 06, 2013 9:11 AM
Subject: RE: [Vantage] Crystal Reports - barcodes scan with and without decimals
Thanks Vic, I will give this a try.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Vic Drecchio
Sent: Tuesday, February 05, 2013 1:41 PM
On your ToText() function, try using the additional arguments:
ToText({your_field},0,"")
The zero forces to NO decimals. I know the INT() should do that but I've
seen cases of formatting in Crystal where the ToText always dumps in
decimals.
The empty quotes ("") tell it to never use a comma (thousands separator).
Karen Schoenung
Sent: Tuesday, February 05, 2013 2:07 PM
Subject: [Vantage] Crystal Reports - barcodes scan with and without decimals
Hi all,
I have a Crystal Report that uses barcodes and formulas such as -
"*"+ToText(Int({orderrel.OrderNum}))+"$I"+"*". We use terminal servers to
connect to Epicor and different printers...On some printers this barcode
scans correctly as the integer only of the order number and a tab
character...On other printers this barcode scans with decimal places (order
number + .00). We have tested it is not the scanner - the same printed
report scans the same way with multiple scanners.
Does anyone have any ideas on what we can check into?
TIA,
Karen
No virus found in this message.
Checked by AVG - www.avg.comhttp://www.avg.com>
Version: 2012.0.2238 / Virus Database: 2639/5583 - Release Date: 02/05/13
Hi all,
I have a Crystal Report that uses barcodes and formulas such as - "*"+ToText(Int({orderrel.OrderNum}))+"$I"+"*". We use terminal servers to connect to Epicor and different printers...On some printers this barcode scans correctly as the integer only of the order number and a tab character...On other printers this barcode scans with decimal places (order number + .00). We have tested it is not the scanner - the same printed report scans the same way with multiple scanners.
TIA,
Karen
decimals.
Karen Schoenung
Hi all,
TIA,
Karen
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
decimals.
Karen Schoenung
Hi all,
TIA,
Karen
Checked by AVG - www.avg.com<http://www.avg.com>
