Crystal reports - equivalent to MS-Access sub-queries
I'm with you. I much prefer complex queries and simple reports. Epicor doesn't give you much to work with unless you want to do some back-end queries on the Progress core database in 4GL during off-hours since you need exclusive access to the db. I've done a couple like this but what a PITA.
Anyway, so what I do is still use Access for a query tool and have Crystal link to Access through ODBC. It might not work well on big complex reports because it adds another layer but I haven't had any trouble with performance for the reports I've tried. I still go through the Vantage interface so the end user doesn't know any difference. And if this is just for your own analysis, I wouldn't even bother with the Crystal report and just do it all in Access.
--- In vantage@yahoogroups.com, "Bruce Ordway" <cooner_55421@...> wrote:
> Hi,
> I'm looking for info/examples of using subqueries and/or temp tables in Crystal.
> Here is a little of the history...
> I have used MS Access/ODBC for a long time to create my own personal Vantage reports.
> Other users would like to have these same reports available.
> Most translate with little problem but...
> Some of these I have not been able to duplicate with BAQ's and/or Crystal.
> The most common problem I'm having is that I use subqueries in Access.
> I build a query and then use it as the datasource for another query. I haven't seen an example of this in Crystal.
> The one that I'm having the most trouble with is similar to the time phase report. In Access I had to create a temporary table and populate it with records from demand tables. I was then able to compare these records with supply tables. I don't know of any way to create a temp table with Crystal.
> Thanks,
> Bruce
Bruce,
I expect you can have more than one connection for Crystal - one to the
BAQ and one to ODBC for Access (I have done this long ago with Excel)
and then link them in Crystal as needed.
Karen
Of Bruce Ordway
Sent: Thursday, August 06, 2009 10:46 AM
Subject: [Vantage] Crystal reports - equivalent to MS-Access sub-queries
Hi,
Crystal.
Vantage reports.
Crystal.
table with Crystal.
Bruce
