Crystal Reports Error 247
You need to run a registry fix called outjoin.reg. Then you'll have
to enter a value in the registry corresponding to the version of ODBC
you have. You can get it along with instructions from Support. It
may even be in the files section of this group. A pretty easy fix.
Brian
--- In vantage@yahoogroups.com, "rocket7247" <jglenn@e...> wrote:
> We are currently using Vantage 5.2, Progress 9.1D. I am attempting
> to create a simple report using Crystal Reports 8.5. When joining
> two tables through ODBC and trying to preview the report, I get the
> following error message:
> [Intersolv][ODBC Progress driver][Progress]** Unable to understand
> after -- "Declare". (247)
> I do not get this error with one table.
> Joan Glenn
Joan Glenn
