Crystal Reports Job Traveler
Hi,
The date formula works, but this is what happens on this one. I admit to
not having much experience on Crystal. Any help you can give me?
Ellen
Of Jennifer
Sent: Monday, April 25, 2011 8:37 AM
Subject: [Vantage] Re: Crystal Reports Job Traveler
Ellen,
Since it's the header it will only pick up the first oper unless you use
WhilePrintingRecords;
Sample:
CStr([joboper.oprseq],0,"") & "<BR>" & CStr([joboper.startdate],
"M/dd/yy")
You may need to play with the format on the date to get it the way you
want. I don't believe you need to include CDate since the start date is
stored as datetime.
If you use the <BR> command for a new line (rather then 2 separate
formulas on different rows) you will need to format the paragraph Text
Interpretation as HTML.
Jenn
"Ellen Lensing" <ellen.lensing@...> wrote:
I am trying to modify the job traveler. All I want to do is have a row
on the job header the shows the job oper num and start date. Ok two
rows. It just repeats the first operation on each page, when I copy and
paste each formula. Tech support doesn't know, I was wondering if anyone
in the group had any experience with editing Crystal reports
Middle West Manufacturing Corp.
Ellen Lensing
Accounting Manager
Phone 262-251-8760
Fax 262-251-8769
anyone in the group had any experience with editing Crystal reports
Ellen Lensing
Accounting Manager
Phone 262-251-8760
Fax 262-251-8769
Ellen,
Since it's the header it will only pick up the first oper unless you use WhilePrintingRecords;
Sample:
CStr([joboper.oprseq],0,"") & "<BR>" & CStr([joboper.startdate], "M/dd/yy")
You may need to play with the format on the date to get it the way you want. I don't believe you need to include CDate since the start date is stored as datetime.
If you use the <BR> command for a new line (rather then 2 separate formulas on different rows) you will need to format the paragraph Text Interpretation as HTML.
Jenn
--- In vantage@yahoogroups.com, "Ellen Lensing" <ellen.lensing@...> wrote:
I am trying to modify the job traveler. All I want to do is have a row on the job header the shows the job oper num and start date. Ok two rows. It just repeats the first operation on each page, when I copy and paste each formula. Tech support doesn't know, I was wondering if anyone in the group had any experience with editing Crystal reports
Ellen Lensing
Accounting Manager
Phone 262-251-8760
Fax 262-251-8769
Jenn
Thanks so much.... I will give this a try. I would think the Epicor
support should know this.
Of Jennifer
Ellen,
Sample:
"M/dd/yy")
stored as datetime.
Jenn
Ellen Lensing
Accounting Manager
Phone 262-251-8760
Fax 262-251-8769
