Crystal Reports ODBC
Looks like a windows update screwed it up. I'm back up and running now.
Of Manasa Reddy
Sent: Friday, June 11, 2010 11:21 AM
Subject: RE: [Vantage] Crystal Reports ODBC
This is what you need Tim,
Summary: ODBC Setup could not be loaded (126)
Book: Support Solutions
Page: 5092MPS
PROBLEM DESCRIPTION
ODBC setup could not be loaded (126)
could not load setup or translator library
For Open Edge 10.0B ONLY.
STEPS TO DUPLICATE
This error has to do with: the registry steps and server path name (step
6)
Following are the steps to setup the DataDirect 4.20 32-Bit Progress
SQL92 v10.0B Driver for MFGSYS version 8.0.
1. Using windows explorer, browse to your
server\epicor\oe100b\netsetup folder.
2. Double click on the SETUP.EXE in the netsetup folder which will
install the OpenEdge 10.0B Shared Network Setup. For the working
directory, you can point to the shared folder on the server. For
example: \\servername\epicor\mfgwrk80
<file:/// <file:///\\> \\servername\epicor\mfgwrk80> .
3. Create and open a new Text document at a workstation (for example:
ODBC.TXT).
4. Copy and paste all of the text below into that new (ODBC.TXT) text
doc.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI\DataDirect 4.20 32-Bit
Progress SQL92 v10.0B]
"APILevel"="1"
"ConnectFunctions"="YYN"
"CPTimeout"="60"
"Driver"="\\\\servername\\epicor\\oe100b\\bin\\PGPRO1019.DLL"
"DriverODBCVer"="4.20"
"FileUsage"="0"
"Setup"="\\\\servername\\epicor\\oe100b\\bin\\PGPRO1019S.DLL"
"SQLLevel"="0"
"UsageCount"="1"
[HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI\ODBC Drivers]
"DataDirect 4.20 32-Bit Progress SQL92 v10.0B"="Installed"
5. Edit two lines of the text document to reflect your servers name.
The two lines are:
Driver =
Setup=
Change the \\Servername <file:/// <file:///\\> \\Servername> to your
server's actual
name. Save the changes.
6. Rename the ODBC.TXT doc to ODBC.REG. This will change the
appearance of the file and allow it to be added to the registry.
7. Double click on the ODBC.REG file which will automatically import
the information into the workstations registry. Setup the ODBC DSN for
the new DataDirect driver.
VERSION NUMBER
XA800
XA803
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
<mailto:manasa@... <mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Late, Travis
Sent: Friday, June 11, 2010 8:25 AM
Subject: [Vantage] Crystal Reports ODBC
I'm hoping someone has a solution to this issue. I started my computer
up today and am receiving this error when I go into my Vantage 8.03 ODBC
connection:
The setup routines for the OpenEdge 10.1B driver ODBC driver could not
be loaded due to system error code 126
Any help is appreciated. The last thing I want to do is reformat my
machine.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Phone: 920-898-1560 Ext.152
Cell: 920-960-0062
Email: tlate@... <mailto:tlate%40m-bco.com>
<mailto:tlate@... <mailto:tlate%40m-bco.com>
<mailto:tlate%40m-bco.com> >
Quality you can see.
People you can trust. TM
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively
for
the individuals and entities to which it is addressed. This
communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are
not
authorized to read,print,retain copy or disseminate this message or any
part
of it.If you have received this message in error, please notify the
sender
immediately by email.
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
connection:
machine.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
Email: tlate@... <mailto:tlate@...>
If you are using Windows XP, you could just do a Windows Restore back to
yesterday. Did a windows update run during the night or sometime
yesterday?
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of Late, Travis
Sent: Friday, June 11, 2010 9:25 AM
connection:
machine.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
Email: tlate@... <mailto:tlate%40m-bco.com> <mailto:
tlate@... <mailto:tlate%40m-bco.com> >
for
communication,
not
part
sender
You might have lost your shared drive.
Of Late, Travis
connection:
machine.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
<mailto:tlate@... <mailto:tlate%40m-bco.com> >
for
communication,
not
part
sender
Page: 5092MPS
PROBLEM DESCRIPTION
STEPS TO DUPLICATE
6)
<file:///\\servername\epicor\mfgwrk80> .
ODBC.TXT).
doc.
"APILevel"="1"
"CPTimeout"="60"
"FileUsage"="0"
"SQLLevel"="0"
"UsageCount"="1"
The two lines are:
Driver =
Setup=
Change the \\Servername <file:///\\Servername> to your server's actual
VERSION NUMBER
XA800
XA803
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Late, Travis
connection:
machine.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
for
communication,
not
part
sender
