Crystal Reports - Packing Slip
Works!
Since I haven't worked with "Linked Tables" before, here are the
mistakes I made:
1) Chose the wrong Linked Table, used the default.
2) Forgot to "Verify Database" in Crystal Reports XI
3) Didn't recognized that linked tables are preceded with
Table_Description, i.e., Customer_TermsCode.
Thank for the help, Nigel.
Regards,
--SF
--- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@...> wrote:
> Yes. Then make sure the field "TermsCode" is listed in "Fields
> Picked" (tab: Report Table | Linked Tables | Description Fields).
> --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@> wrote:
> > Do you add the Ordernum link to the ShipDtl in Report Data
> Definitions?
> > --SF
> > --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
> wrote:
> > > We got the TermsCode to print by amending the data definition and
> > > adding in the OrderNum link to the ShipDtl table.
> > > I haven't found a way to add in the actual description but I keep
> > > meaning to an ODBC connection to the layout to lookup the
> Description
> > > from the DB itself. Just haven't gotten around to it yet.
> > > (We're on v8.03)
> > > Nigel.
> wrote:
> > > > Has anybody been able to print the "TERMS" from Sales Order
> Entry on a
> > > > Packing Slip?
> > > > --SF
Has anybody been able to print the "TERMS" from Sales Order Entry on a
Packing Slip?
--SF
meaning to an ODBC connection to the layout to lookup the Description
(We're on v8.03)
Nigel.
> Packing Slip?
> --SF
Do you add the Ordernum link to the ShipDtl in Report Data Definitions?
--SF
> (We're on v8.03)
> Nigel.
> > Packing Slip?
> > --SF
Definitions?
> --SF
Description
> > (We're on v8.03)
> > Nigel.
Entry on a
> > > Packing Slip?
> > > --SF
