Hello Group
I found this post and hope someone has figured out how to do this.
I would like to launch a custom (odbc) rpt from a button and would
like to pass it parameters.
TIA
Mark Dupuis
--- In vantage@yahoogroups.com, "steve.thoms" <steve.thoms@...>
TIA
Mark Dupuis
wrote:
>with
> Were you (or has anyone been) able to figure out how to launch a
> custom report using LaunchFormOptions?
> I've customized the Custom Report form and pre-populated the form
> the right path to the report (confirmed since the same path worksfor
> using another method). But it would appear that the Custom Report
> process doesn't use the text in the Report text box as the actual
> input. Maybe there's an option somewhere to set the actual value
> the report path?lfo)
> Or has someone figured out a different (simpler?) way to launch a
> custom Crystal Report from a button?
> -Steve
> --- In vantage@yahoogroups.com, Fons van der Beek
> <fons.vanderbeek@> wrote:
> > Tnx, i''ll keep you informed............
> > Michael McWilliams schreef:
> > > For custom report I believe you use.
> > > ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UI.CustomReport",
> > >set
> > > Then customize the form that launches for an on load event and
> > > the path of the report using the script editor. You then haveto
> > > use subproccess calling maint. to set this custom version ofthe
> > > form to load from you calling form.report
> > > I am not sure how the launch form options work for a custom
> > > so the user would have to input their parameters. You may evenbe
> > > able to bypass using the subproccess calling if you can figureout
> > > the launch form options. If you do let me know because epicorwas
> > > clueless when I asked for any type of info on this.the
> > > --- In vantage@yahoogroups.com, "Michael McWilliams"
> > > <mmcwilliams22@> wrote:
> > >> Here is an example for the standard report. I know I have
> > >>System.Object,
> > > other
> > >> one also I just have to look for it.
> > >> Private Sub btnEpiCustom1_Click(ByVal sender As
> > >>lfo)
> > > ByVal
> > >> e As System.EventArgs) Handles bntEpiCustom1.Click
> > >> Dim QuoteHead As EpiDataView = Ctype(oTrans.EpiDataViews
> > >> ("QuoteHead"),EpiDataView)
> > >> Dim strQuoteNum As String = QuoteHead.dataView(QuoteHead.Row)
> > >> ("QuoteNum")
> > >> Dim lfo as LaunchFormOptions = new LaunchFormOptions()
> > >> lfo.IsModal = true
> > >> lfo.ValueIn = strQuoteNum
> > >> ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UIRpt.QuotForm",
> > >> End Subyou
> > >>> Actualy both
> > >>> I have some customized reports from Vantage and i have some
> > >> reports
> > >>> based on OBDC with various user input.
> > >>>> Do you want to launch a Vantage crystal report or a report
> > >>>>Note:
> > >> created
> > >>>> yourself?
> > >>>> --- In vantage@yahoogroups.com, "fonsvanderbeek"
> > >> <fons.vanderbeek@>
> > >>>> wrote:
> > >>>>> Hi,
> > >>>>> Does anybody have a code example for calling a crystal
> > > report
> > >> from
> > >>>>> within the Customization?
> > >>>>> e.g.
> > >>>>> To display a report by clicking a Commandbutton?
> > >>>>> Tnx
> > >>>> Useful links for the Yahoo!Groups Vantage Board are: (
> > >>>>to
> > >> You must have already linked your email address to a yahoo id
> > >> enable access. )Report
> > >>>> (1) To access the Files Section of our Yahoo!Group for
> > >>>>You
> > >> Builder and Crystal Reports and other 'goodies', please goto:
> > >> http://groups.yahoo.com/group/vantage/files/.
> > >>>> (2) To search through old msg's goto:
> > >> http://groups.yahoo.com/group/vantage/messages
> > >>>> (3) To view links to Vendors that provide Vantage services
> > > goto:
> > >> http://groups.yahoo.com/group/vantage/links
> > >>>> Yahoo! Groups Links
> > >>> [Non-text portions of this message have been removed]
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> must have already linked your email address to a yahoo id to enablegoto:
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Yahoo! Groups Links
