Crystal Reports Selection Expert
RESOLVED:
I removed the link of Customer.Company -> QuoteDtl.Company and replaced with Customer.CustNum -> QuoteDtl.CustNum.
My formula that works is below:
if {?CustID} = "*"
then
{QuoteHed.DateQuoted} = {?My Parameter}
else
{QuoteHed.DateQuoted} = {?My Parameter} and
{Customer.CustID} = {?CustID}
Thanks.
--sf
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> What is your selection formula?
> Linda
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415
> Sent: Tuesday, May 18, 2010 11:52 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Crystal Reports Selection Expert.
> OK. For some reason when I use the above formula, my selection doesn't include the date selection, it simply selects all the records from the quote table.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Linda Lowney" <llowney@> wrote:
> > I have one where the parameter is “SelectCustId.” If the user leaves it blank then it prints all customers. I created a formula called “bSelectedCustId” as follows:
> > if {?SelectCustId} = "" or {?SelectCustId} = {Customer.CustID} then
> > true
> > else
> > false
> > Then in the selection formula I have:
> > {OrderRel.Company} = “xxxx” and {@bSelectedCustId} = true
> > Hth,
> > Linda
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of sanfranc415
> > Sent: Monday, May 17, 2010 5:29 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Crystal Reports Selection Expert.
> > I'm trying to suppress/hide a Selection Expert Parameter.
> > Currently, I have a parameter that prompts the user for the CustID. The user would like to have the option to either enter the CustID or leave it blank, which leaving it blank would generate the report with all CustID.
> > Thanks,
> > --sf
--sf
true
else
false
Hth,
Linda
--sf
> true
> else
> false
> Hth,
> Linda
> Thanks,
> --sf
Linda
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Linda Lowney" <llowney@...> wrote:
> true
> else
> false
> Hth,
> Linda
> Thanks,
> --sf
