Crystal reports suppress using a where statement
Use a global variable. Create it in the report/group header with a
formula of "global BooleanVar foundsub = false", add another formula
field in the detail line that does "... if {subcontract check...} then
foundsub := true" and then do a conditional suppress of the detail
section based on that field. The global variable will be set once the
first subcontract line is encountered, and because it's global, remain
that was for all future detail lines.
Brian.
Of michael.hutcheson@...
Sent: Monday, May 16, 2011 8:54 AM
Subject: [Vantage] Crystal reports suppress using a where statement
Hello,
I have the below data in a report (dates in dd/mm/yy), grouped by job:
Job: 123
OP SEQ Desc Type: Date
20 Stamping 01/02/11
30 CNC 01/03/11
40 Hand Dress 01/04/11
50 Machining Sub Contract 01/05/11
60 Inspection 01/06/11
What statement would I use to only show Op Seq's 20,30,40 and 50? I.e.
Hide anything after the sub contract. Basically I want to say if the
date is greater than an op that is a sub contract, then suppress - but
how do I actually write this?
Regards,
Michael
Hello,
Job: 123
30 CNC 01/03/11
What statement would I use to only show Op Seq's 20,30,40 and 50? I.e. Hide anything after the sub contract. Basically I want to say if the date is greater than an op that is a sub contract, then suppress - but how do I actually write this?
Regards,
Michael
You could try using a running total.
Basically the idea would be to create RTotal variable which increments
when Type=Sub Contract (you could just use the Count function), and
which resets at the change of the group. You could then conditionally
suppress the detail lines if your RTotal variable isn't zero.
-bws
Hello,
Job: 123
30 CNC 01/03/11
Regards,
Michael
