I found the folder thanks for triggering my mind it is in
\\servername\epicordata share\reports then the user name. on our system
Dan
Quoting cooner_55421 <cooner_55421@...>:
Dan
> The default install path on the server is c:\program files\epicor
> software\epicordata
> But that can be changed by the user.
> Do you have a folder named something like this?
> \\server name\epicor share\EpicorData\Reports\username
> --- In vantage@yahoogroups.com, "dctechnologiesllc10" <dan@...> wrote:
>> Has anyone been able to find the XML files for 9.05.606
>> I have been customizing the Traveler.rpt to look like our set up
>> from Vantage 8.03 when I go throught the refresh to set check the
>> form or if i run it through Epicor I get an Connection error
>> ADO.NET (XML)
>> file path C:\MfgSysData\Reports\PGouni\Job Traveler04841.XML
>> I have looked where they were on the Vantage server under
>> \\servername\epicor\mfgsysdata\Reports\then under the specific
>> employee folder that had used it. I do not find this in E9.05
