Crystal Runtime Location
Karen,
That path exists on my machine, yes, but I have the developer edition of Crystal. It does not exist on other user's machines - I've been through several of them. The folder structure is different, and there are piles and piles of dlls, but no executables. And trying to run BAQ report designer on these other machines fails, too.
This wouldn't typically be troublesome, as I expect I'll do most of the report creation, but I have a few reports that I didn't build from BAQs and would like to launch from Vantage. To do that with a process link, I need to define the location of an executable. The "CustomeReport.dll" doesn't work for this kind of a report, since there's no XML file generated.
Hmmm. I might have to make like a stream and work my way around this via some other path, if the runtime will only work with xml files.
Thanks!
Lynn
--- In vantage@yahoogroups.com, "Karen Schoenung" <kschoenung@...> wrote:
> C:\Program Files\Business Objects\Crystal Reports 11.5\crw32 (.exe)
> This is the path shown in Vantage - BAQ report designer, actions, BAQ
> report options...
> Check there to see if you have a path that is actually the path of your
> crystal executable...
> FYI,
> Karen
> Of lynntw83
> Sent: Friday, September 25, 2009 12:52 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Crystal Runtime Location
> Does anyone know how to find the Crystal Runtime executable? IS there a
> Crystal Runtime executable? I have a couple of Crystal reports that I
> did not build in Vantage but would like to access via a process link.
> That requires me to specify the location of the executable, but I can't
> find one in any of what seem to be the plausible places. I'm on .408
> SQL.
> Thanks,
> Lynn Thomas
> SAIC
> with apologies if this is a redundant post; I don't see the one I
> thought I put up a couple of hours ago.
Does anyone know how to find the Crystal Runtime executable? IS there a Crystal Runtime executable? I have a couple of Crystal reports that I did not build in Vantage but would like to access via a process link. That requires me to specify the location of the executable, but I can't find one in any of what seem to be the plausible places. I'm on .408 SQL.
Lynn Thomas
SAIC
with apologies if this is a redundant post; I don't see the one I thought I put up a couple of hours ago.
report options...
FYI,
Karen
Of lynntw83
SQL.
Lynn Thomas
SAIC
