Michelle,
I imagine it depends on what product you are using. We are using
Vantage 8.0. Epicor has a general FYI document on how to modify a
standard Crystal Report.
http://fyi.epicor.com/NR/exeres/3F2DD992-3FB8-4E57-8FE6-577FA4D386DE.htm
<http://fyi.epicor.com/NR/exeres/3F2DD992-3FB8-4E57-8FE6-577FA4D386DE.ht\
m>
m>
The Crystal Report Developer should have come with your software.
Writing you own report and putting that on the menu system is fairly
easy. Probably a 4 on a 1 - 10 scale. I've found modifying their
reports to be more involved (a 6 or 7 out of 10).
Hope this helps.
Steve Pybus
Anchor Fabrication
--- In vantage@yahoogroups.com, "Michelle VonBokern" <mvonbokern@...>
m>
m>
Hope this helps.
Steve Pybus
Anchor Fabrication
wrote:
>[Non-text portions of this message have been removed]
> Morning everyone.
> I am wondering if there is anything that can be done to change two
> fields on the crystal Sales Order Acknowledgement report.
> Up toward the top of the form there is a NEED BY date that is printed,
> and then specifically for each line item there is a DATE field.
> I would like to change both these fields, if possible, to read SHIP
> WEEK.
> Can anyone tell me if I can do this, and if so how? :-)
> Thanks in advance!
> Michelle Von Bokern
> Office Manager
> Advance Engineering Co.
> PH: 630-628-3445
> FAX: 630-628-3449
> mvonbokern@... <mailto:mvonbokern@...
