Crystal - shared variables and sub reports
Hi All,
I'm tweaking the sales order acknowledgement report to make it work when
printing for more than one sales order at a time.
There were problems where the order line misc charges variable didn't
reset so charges on one order carried over to another order.
I fixed this but now this problem started happening with the order
header charges. It was working fine until I changed the order line
charges.
Both sub reports use a shared var to pass the totals back to the main
report.
Both sub reports have a reset formula in the sub report header to set
the value to 0. This works in the line charges but not the header
charges.
I've also noticed this in another report where I used the same technique
with shared vars and one only is working.
Is this a bug with Crystal or do you have do something "special" when
using more than one sub report and both use a shard var to send vales
back?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
