Crystal sub report
Charlie, I have a similar report looking at the non conformance and DMR
action tables with a sub report. Email me direct and Ill send you a
copy of the .rpt file
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Charlie Wilson
Sent: Wednesday, April 22, 2009 2:23 PM
Subject: [Vantage] Crystal sub report
All
Im building a DMR crystal report and I need to pass the DMR number to a
sub
report that is going to pull The action data. How can I go about doing
this?
~Charlie
All
Im building a DMR crystal report and I need to pass the DMR number to a sub
report that is going to pull The action data. How can I go about doing this?
~Charlie
You should be able to just create a formula with the following:
shared numbervar (variable name) := {DMR Number Field}
Then in the sub report put the following in a formula
shared numbervar (varable name)
You will also need to link the subreport, if you go to the main report design mode, right click the sub report and click change subreport links, you can change the links there...
If you need more help let me know.
Brad
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...> wrote:
> All
> ~Charlie
