Crystal subreport on RMA Form
Thanks a lot Gary, that worked a treat, amazing how things work when you
do them properly!!
Kind regards
Stuart Noble
Thompson Meat Machinery
Of Gary Parfrey
Sent: Friday, 3 August 2007 4:27 PM
Subject: RE: [Vantage] Crystal subreport on RMA Form
Stuart
When the data moves into the temporary files and are passed to the form,
the fields often looses there field type. SO the RMA Line Number
becomes a string, hence you cannot link.
What you do is in your main form create two formulae fields. One for
RMA number and the other for RMA lines casting them to a number
Calc
To Number({Field})
You will then find you can link the ODBC subreport to these calculated
fields as the ODBC shows the fields in there true field type.
If you need a sample I can send you one directly
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Hi Group,
I am trying to add a subreport to the standard crystal form For the RMA
form. The subreport I am trying to add is to show the serial number
associated with the current RMA part.
When I try to link the subreport, I cannot see anyway to link the
SerialNumber.RMALine to the field RMADtl.RMALine.
This link would give me the Serial Number associated with the
appropriate RMA Line. I can create the link in a BAQ, so know that it
works, but the field SerialNumber.RMALine does not show up in the
subreport links table.
Can anyone help, or if anyone has a RMA form which they have created to
show the serial number, would they mind passing it on?
I am sure if I created my own crystal report I could make this link, the
problem I believe is that the field is not selected to be used or
available in the canned EPICOR Crystal RMA form.
Thank you very much.
Stuart Noble
What version of Vantage Stuart? We're on 8.03.305H and our RMA form already
has serial numbers on it. (The Detail Section to be specific.)
Mark W.
Good point Mark!
We are on 6.10.540
Stuart Noble
stuart@...
' + 61 7 3803 6643
Of Mark Wonsil
Sent: Friday, 3 August 2007 9:19 AM
RMA
already
Mark W.
Stuart
Calc
To Number({Field})
Gary Parfrey
Of Stuart Noble
Sent: 02 August 2007 23:53
Subject: [Vantage] Crystal subreport on RMA Form
Hi Group,
Stuart Noble
