Crystal ? (Vantage 5.1 and Crystal 8.5)
Thanks all for your help. And thanks Aaron for pointing me in the
right direction. I had the suppress formulas in Suppress Blank
Section and I just put them in the Suppress(No Drill Down) area and
now everything works properly.
--- In vantage@yahoogroups.com, "Dale Norris" <dnorris@b...> wrote:
> If you right click on the PNG do you get an option to Format
Graphic? If so, the option to suppress in on the Common tab. Check
the box and then use the button to the right to create the formula.
> Dale Norris
> IT Manager
> Bullen Ultrasonics
> >>> jyargeau@t... 10/13/2005 9:57 AM >>>
> I guess my question is regarding the signature file, ours is a PNG
> file that we use and where do I find the properties to put in a
> suppress formula. Again thanks for the help.
> > On our forms that need signatures we scanned them in as BMPs. We
> then placed on the form one at a time, setting the properties of
the
> BMP to suppress if PoHeaderBuyer does not equal {buyer name}. You
> just stack all the BMPs on top of each other. Only the one that
> equals the buyer shows up. This did not necessitate any special
> footers or secondary formulas.
> > Hope this helps.
> > Dale Norris
> > IT Manager
> > Bullen Ultrasonics
> > >>> jyargeau@t... 10/13/2005 8:49 AM >>>
> > I have a Crystal question and I had asked about this previously,
> but I
> > will try again. On the PO Crystal form, I have created digital
> > signatures to appear on the Crystal form. (Thanks to those on the
> list
> > for help in doing this). In Crystal, I basically have two
> formuals.
> > The first formula checks the POHeaderBuyer field for one of three
> > people. If the PoHeaderBuyer = one of those three, then print
the
> > field otherwise leave it blank. Then I have 3 group footers each
> with
> > the digital signature for one of these 3 buyers. The second
> formula
> > suppresses the footer line if the PoHeaderbuyer is not equal to
the
> > buyer's signature. This works perfectly within Crystal. One
buyer
> > name shows with one signature or blanks if none of the three
buyers
> are
> > present. The form is saved in the userform directory. This form
is
> > then made the default form in Vantage. Now in Vantage when you
> bring
> > up a PO and preview or print, all three signatures are present
all
> the
> > time. No lines are suppressed. I called Epicor support, but of
> course
> > was told this is part of custome programming and thus billable.
> Does
> > anyone have any idea why this works in Crystal and not in
Vantage.
> As
> > always your help is appreciated. TIA.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> > Yahoo! Groups Links
access. )
> Yahoo! Groups Links
I have a Crystal question and I had asked about this previously, but I
signatures to appear on the Crystal form. (Thanks to those on the list
for help in doing this). In Crystal, I basically have two formuals.
people. If the PoHeaderBuyer = one of those three, then print the
field otherwise leave it blank. Then I have 3 group footers each with
the digital signature for one of these 3 buyers. The second formula
suppresses the footer line if the PoHeaderbuyer is not equal to the
buyer's signature. This works perfectly within Crystal. One buyer
name shows with one signature or blanks if none of the three buyers are
present. The form is saved in the userform directory. This form is
then made the default form in Vantage. Now in Vantage when you bring
up a PO and preview or print, all three signatures are present all the
time. No lines are suppressed. I called Epicor support, but of course
was told this is part of custome programming and thus billable. Does
anyone have any idea why this works in Crystal and not in Vantage. As
On our forms that need signatures we scanned them in as BMPs. We then placed on the form one at a time, setting the properties of the BMP to suppress if PoHeaderBuyer does not equal {buyer name}. You just stack all the BMPs on top of each other. Only the one that equals the buyer shows up. This did not necessitate any special footers or secondary formulas.
Hope this helps.
Dale Norris
IT Manager
Bullen Ultrasonics
>>> jyargeau@... 10/13/2005 8:49 AM >>>
Yahoo! Groups Links
> Hope this helps.
> Dale Norris
> IT Manager
> Bullen Ultrasonics
but I
list
formuals.
with
formula
are
bring
the
course
Does
As
access. )
> Yahoo! Groups Links
If you right click on the PNG do you get an option to Format Graphic? If so, the option to suppress in on the Common tab. Check the box and then use the button to the right to create the formula.
Dale Norris
IT Manager
Bullen Ultrasonics
>>> jyargeau@... 10/13/2005 9:57 AM >>>
> Hope this helps.
> Dale Norris
> IT Manager
> Bullen Ultrasonics
but I
list
formuals.
with
formula
are
bring
the
course
Does
As
access. )
> Yahoo! Groups Links
Yahoo! Groups Links
Right click on the graphic file you have inserted and select "Format
Graphic".
Patrick Winter
Joanne Yargeau
Sent: Thursday, October 13, 2005 8:58 AM
Subject: [Vantage] Re: Crystal ? (Vantage 5.1 and Crystal 8.5)
I guess my question is regarding the signature file, ours is a PNG file that
we use and where do I find the properties to put in a suppress formula.
> Hope this helps.
> Dale Norris
> IT Manager
> Bullen Ultrasonics
but I
list
formuals.
with
formula
are
bring
the
course
Does
As
> Yahoo! Groups Links
------------------------ Yahoo! Groups Sponsor --------------------~--> Get
Bzzzy! (real tools to help you find a job). Welcome to the Sweet Life.
http://us.click.yahoo.com/A77XvD/vlQLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
