Crystal with ODBC and Vantage 5.1
Babette,
This is our procedure for SQL89...should be the same for SQL92. You'll
need to add the following lines to that autoexec.bat:
SET DLC=V:\PROGRESS
SET IDLC=V:\PROGRESS
SET PROMSGS=V:\PROGRESS\promsgs
SET IPROMSGS=V:\PROGRESS\promsgs
SET PROCFG=V:\PROGRESS\progress.cfg
...where V is the drive letter you've mapped to run Vantage from.
You'll also want to copy V:\PROGRESS\BIN\prosql32.dll to the
C:\WINDOWS\SYSTEM folder (for win9x) or C:\WINDOWS\SYSTEM (for
NT-based). Finally, after you have opened Crystal once, edit the
registry key HKCU\Software\SeagateSoftware\Crystal
Reports\DatabaseOptions\OuterJoin\OpenIngres and set it to ivpro15 for
SQL92 or ivpro14 for SQL89 (if you are not sure just use ivpro15).
AE
On Tue, 2002-08-06 at 08:08, Babette Welch wrote: 1) Using Crystal
Version 8. Pro
2) Only lines in Autoexec.bat
SET BLASTER=A220 I7 D1 H7 P330 T6
SET SBPCI=C:\AUDIOPCI
SET CLASSPATH=C:\Program Files\PhotoDeluxe 2.0\AdobeConnectables
SET CI_HOLOS_CLI=C:\Program Files\Seagate Software\Open Olap\
BW
________________________________________________________________________
Message: 5
Date: Mon, 5 Aug 2002 09:59:19 -0400
Subject: Re: Crystal with ODBC and Vantage 5.1
What do you have listed in your Autoexec.bat file for the following
variables:
dlc
idlc
promsgs
ipromsgs
Troy Funte
----- Original Message -----
Sent: Monday, August 05, 2002 9:53 AM
Subject: [Vantage] Crystal with ODBC and Vantage 5.1
Still having problems connecting to Vantage thru Crystal!!!!!
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Using Control Panel > ODBC Data Source > User DSN >
Progress > Test Connect
Works Fine
Yet trying to connect thru Crystal we get an error.
".... unable to open message PROMSGS"
Checked:
Autoexec.bat
other environmental variables
Cant' find the problem.
Any suggestions?
On or off-line.
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.226.9747 ext 235
906.228.0951 fax
Yahoo! Groups Sponsor
ADVERTISEMENT
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Works Fine
Checked:
Autoexec.bat
Any suggestions?
On or off-line.
Thanks in advance
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
What do you have listed in your Autoexec.bat file for the following variables:
dlc
idlc
promsgs
ipromsgs
Troy Funte
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Works Fine
Checked:
Autoexec.bat
Any suggestions?
On or off-line.
Thanks in advance
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
Is Crystal version 8, Professional?
Mike Gilchrist
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Works Fine
Checked:
Autoexec.bat
Any suggestions?
On or off-line.
Thanks in advance
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
<http://rd.yahoo.com/M=231082.2206868.3656198.1829184/D=egroupweb/S=17050071
83:HM/A=1165770/R=0/*https://www.gotomypc.com/tr/yh/cpm/egr/300_g2_01/g22lp?
Target=mm/g22lp.tmpl>
<http://docs.yahoo.com/info/terms/> Terms of Service.
1) Using Crystal Version 8. Pro
BW
Message: 5
dlc
idlc
promsgs
ipromsgs
Troy Funte
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Works Fine
Checked:
Autoexec.bat
Any suggestions?
On or off-line.
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
Babette,
Are you using the SQL-92 drivers that come with Vantage, or separate ODBC drivers that you purchased.
Troy Funte
Liberty Electronics
Sent: Tuesday, August 06, 2002 8:08 AM
Subject: [Vantage] Re: Crystal with ODBC and Vantage 5.1
BW
Message: 5
dlc
idlc
promsgs
ipromsgs
Troy Funte
Vantage 5.10.125
Progress 9.1C
Merant ODBC 3.60
Works Fine
Checked:
Autoexec.bat
Any suggestions?
On or off-line.
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
