Cumulative BOM Blank Title 109215
There is a summary BOM report in the system, and if I remember correctly it should add up all parts (including child assemblies). But play with it.
In version 8.03 and beyond it is a crystal report so you can change it if needed.
It would be in the reports section of the engineering module.
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of daniel_hunter1980
Sent: Tuesday, April 10, 2012 8:29 AM
Subject: [Vantage] Cumulative BOM
Is it possible to output a form of cumulative BOM on vantage. Currently our setup is using a production based bom with 500+ parts. Over time we have seen parts get duplicated either as material on the top level or behind top level sub assembly parts. Our purchasing team exports this information to excel where they manually go sort through this, pretty much creating a seperate purchasing BOM.
It might also highlight where parts are wrongly being requested by production to be included on the bom, ie they already exist.
So take for example I want to know how many M5 x 30.0 LG cap head screws are used with a top level assembly. How can I go about doing this?
Thanks in advance
Regards
Dan
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: manasa@...<https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: sentto-20369-109215-1334064565-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=622225034&domain=weldcoa.com>
Message Score: 2
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=622225034&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=622225034&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
Thanks in advance
Regards
Dan
