Custom Actions Menu Item Disabled after record retrieval
Thanks, that did the trick. I'm not real excited about just reenabling it all the time, but I guess that's what it will take.
Dale.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> If you added it to an already there menu, it is possible that Epicor is
> disabling the parent when you change records, I'd re-enable it on Notify
> Initialize. Such has mytool.enabled=true;
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com> *
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Wed, Mar 7, 2012 at 1:08 AM, Dale the Magnificent <dmumper1@...>wrote:
> > Greetings.
> > I'm in my first foray into adding an Actions Menu item to our Epicor 9.05
> > system. The menu launches a custom .Net app from the Opportunity/Quote
> > Entry form. It shows up and works fine when the form first opens, but once
> > I retrieve a quote, the menu item becomes disabled. Is there some property
> > that I have to set to make it stay enabled?
> > The same type of setup works fine on the Part Maintenance form, so I'm
> > scratching my head.
> > Any pointers here would be appreciated.
> > Thanks.
> > Dale.
Greetings.
I'm in my first foray into adding an Actions Menu item to our Epicor 9.05 system. The menu launches a custom .Net app from the Opportunity/Quote Entry form. It shows up and works fine when the form first opens, but once I retrieve a quote, the menu item becomes disabled. Is there some property that I have to set to make it stay enabled?
The same type of setup works fine on the Part Maintenance form, so I'm scratching my head.
Thanks.
Dale.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Greetings.
> scratching my head.
> Thanks.
> Dale.
Check the company config for quoting. Make sure to allow changes and
probably take the change log off.
Charlie Smith
2W Technologies LLC, Sr. Business Consultant
Phone: (312) 533-4033 x8046
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
<http://www.facebook.com/pages/Chicago-IL/2W-Technologies-LLC/1391945694
32409> www.2WTech.com <http://www.2wtech.com/>
Of Dale the Magnificent
Sent: Wednesday, March 07, 2012 12:08 AM
Subject: [Vantage] Custom Actions Menu Item Disabled after record
retrieval
Greetings.
enabled?
scratching my head.
Thanks.
Dale.
