Custom Code Report - warnings on system updateable BAQs
Problem: There are warnings on the Custom Code report for many system updatable BAQs. The warnings are BAQConstants.CurrentCompany is obsolete. I have fixed these errors on our own updatable BAQs but I do not know how to fix them on locked system updatable BAQs.
Here is an example of just one of the many warnings.
After I go to this BAQ and see this in the header.
My goal was to fix the issue but I am unable to modify a system query.
This is just one example of the system updateble BAQs with warnings that are listed on the Custom Code Report.
We were a Multi-Tenant customer but 2 years ago moved to Dedicate Tenant. I do not know if this has anything to do with the issue. Our Pilot environment is at version
Thoughts? Does anyone else have the issue?
What is the BAQ in question?
Sorry. My images disappeared.
Custom Code Warning:
Here is the BAQ
I’d make a case with Epicor. Since us users can’t update anything System we can’t fix it. It may be an unused BAQ these days but just in case better to let them know.
I wanted to double check that this is truly a system BAQ and that it is out of my control. Thank you for the confirmation. I created an EpiCare case and am waiting for a response.
There are at least 20 of these system updateable BAQs on the custom code report list with warnings.
We go LIVE on this weekend with 2026. I have been doing testing. I think we are ready but these are a bunch of warnings on the custom code report.
Never knew about the ā€˜Custom Code Report’ ! - thanks. We have a bunch of warnings as well, mostly relating to BAQConstants.CurrentCompany.
Typically ones starting with a ā€œzā€ are but I checked our Pilot and we do have that BAQ.
(Edit to fix mistake)
It is a problem ticket, date 7-9-2026.
We are to ignore the warnings on the system updatable BAQs.
