Custom fields in built in report
Thanks Jim
I was thinking in this line too.
I actually started on this already
On Wed, Jul 3, 2013 at 12:36 PM, jckinneman <jckinneman@...> wrote:
> To make life easier you can setup a master report, use variables to
> establish the sorting and filtering. This step would be pretty much in line
> with the effort if you could pass a parameter(s). Copy the report and
> change the values of the variables to adjust the filtering and sorting.
> When the time comes to modify the report take the master copy, make the
> changes, then copy and adjust the values on the cloned copies. Copying and
> changing the variables would add just a few minutes to the process.
> Jim Kinneman
> Encompass Solutions, Inc
> --- In vantage@yahoogroups.com, Ephraim Feldman <effgroups@...> wrote:
> > Right but that requires me to keep mutiple reports that are really the
> same
> > only different filter so maintenance becomes harder
> > But actually for the mean time it could be a good solution
> > thanks
> > On Wed, Jul 3, 2013 at 12:17 PM, jckinneman <jckinneman@...> wrote:
> > > Depending on what you want to do you may be able to use Report Styles
> > > instead. Each Report style would sort/filter differently.
> > > Jim Kinneman
> > > Encompass Solutions, Inc.
> > > --- In vantage@yahoogroups.com, Ephraim Feldman <effgroups@> wrote:
> > > > I need a field the user should select at the time of printing and
> there
> > > is
> > > > no UD fields in the reportparam table
> > > > On Wed, Jul 3, 2013 at 11:46 AM, Am�lie Pelletier <
> > > > amelie.pelletier@> wrote:
> > > > > Why don't you just use one of the available field in one of the
> table
> > > > > already in use in the job pick list ? You'll save yourself the
> trouble
> > > to
> > > > > try to add a table in a report data definition. (example:
> character 01,
> > > > > shortchar01 ect.)
> > > > > *Am�lie Pelletier*
> > > > > *Analyste Programmeur / Program analyst*
> > > > > [image: cid:image001.jpg@]
> > > > > *230, Boulevard Nilus-Leclerc*
> > > > > *L'Islet, Qu�bec (Canada)*
> > > > > *G0R 2C0*
> > > > > *T�l�phone: 418-247-3986 ext. 2390*
> > > > > *Fax: 418-247-7925*
> > > > > *amelie.pelletier@ <brigitte.savoie@>*
> > > > > *P** *Est-ce n�cessaire d'imprimer ce message?
> > > > > *Please consider the environment before printing this email**.*
> > > > > [Non-text portions of this message have been removed]
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > > > > have already linked your email address to a yahoo id to enable
> access.
> > > > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > > and
> > > > > Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi all
I'm trying to add a custom field on the Job pick list report to be passed
to crystal so i can do some filtering in crystal based on this.
In the Reportparam table there is no UD fields to be used.
How can i accomplish this?
Why don�t you just use one of the available field in one of the table
already in use in the job pick list ? You�ll save yourself the trouble to
try to add a table in a report data definition. (example: character 01,
shortchar01 ect.)
*Am�lie Pelletier*
[image: cid:image001.jpg@01CD5525.2091A820]
*G0R 2C0*
*Fax: 418-247-7925*
*amelie.pelletier@... <brigitte.savoie@...>*
*P** *Est-ce n�cessaire d�imprimer ce message?
I need a field the user should select at the time of printing and there is
> shortchar01 ect.)
> *Am�lie Pelletier*
> *G0R 2C0*
> *Fax: 418-247-7925*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Depending on what you want to do you may be able to use Report Styles instead. Each Report style would sort/filter differently.
Jim Kinneman
> On Wed, Jul 3, 2013 at 11:46 AM, Amélie Pelletier <
> > Why don't you just use one of the available field in one of the table
> > already in use in the job pick list ? You'll save yourself the trouble to
> > shortchar01 ect.)
> > *Amélie Pelletier*
> > [image: cid:image001.jpg@...]
> > *L'Islet, Québec (Canada)*
> > *G0R 2C0*
> > *Téléphone: 418-247-3986 ext. 2390*
> > *Fax: 418-247-7925*
> > *P** *Est-ce nécessaire d'imprimer ce message?
Right but that requires me to keep mutiple reports that are really the same
thanks
> Jim Kinneman
> is
> to
> > > shortchar01 ect.)
> > > *Am�lie Pelletier*
> > > *G0R 2C0*
> > > *Fax: 418-247-7925*
> and
To make life easier you can setup a master report, use variables to establish the sorting and filtering. This step would be pretty much in line with the effort if you could pass a parameter(s). Copy the report and change the values of the variables to adjust the filtering and sorting. When the time comes to modify the report take the master copy, make the changes, then copy and adjust the values on the cloned copies. Copying and changing the variables would add just a few minutes to the process.
Jim Kinneman
> thanks
> > Jim Kinneman
> > is
> > to
> > > > shortchar01 ect.)
> > > > *Amélie Pelletier*
> > > > *G0R 2C0*
> > > > *Fax: 418-247-7925*
> > and
