I think you have it right. While it is best practice to preserve the baseresource file, keep in mind to get the client to use your customresource file, you will need to modify the config file so it will use your new file. You can modify the server config file with the ConfigEditor.exe in the Client folder and then use the ClientZipInstaller to include the config file in your deployment zip as well.
-Rick Bird
IT Software Administrator
Rowmark, LLC.
-Rick Bird
Rowmark, LLC.
--- In vantage@yahoogroups.com, "Joshua Giese" <jgiese@...> wrote:
> Ahh so I want to find that resource in the baseresource file for custom1-5
> and then just create a new resource file, the customresource file, that
> has the same index as the one listed in the base. Does that sound
> accurate? It is all based on a per client basis I will have to add the
> custom resource file to the deployment zip yeah
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905607A-SQL64
> Of that_guyy
> Sent: Wednesday, July 11, 2012 1:12 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Custom menu icons
> Joshua,
> Not sure I exactly understand what you are trying to accomplish.
> You should already have a list of icon's in menu maintnenace.
> The Resource Editor allows you to change or add new image resouces. Now
> depending on what type of image resource each is determines WHERE in the
> application that image shows up. It is best to modify the images attached
> to MenuCustom3-MenuCustom5 (or other ones if you'd like), as I don't see a
> way to create new images and indicate what type they would be.
> Once you make the change and save, you will need to exit Epicor and log
> back in for the changes to show up.
> Also, keep in mind that the client seems to use the local client copy of
> the ResourceImages file. I don't know if you instead change the server
> ResourceImage file, if it updates when you open Epicor again. That isn't
> detailed in the Guide, may need an Epicor call to understand the
> mechanics.
> -Rick Bird
> Rowmark, LLC.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Joshua Giese" <jgiese@> wrote:
> > Great! How would I go about getting that to show up in the drop down in
> > menu maintenance? There are some icons already in Epicor I could use,
> just
> > not sure how to get it to show up in the dropdown.
> > Joshua Giese
> > CTO
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of that_guyy
> > Sent: Wednesday, July 11, 2012 8:27 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Yes, this is done with the 'Resource Editor,' which you can install from
> > your Epicor server.Epicor905>Utilities>EpiResourceEditor.
> > There is a short how to starting on page 260 of the Epicor ICE 2.5 User
> > Experiance and Customization Guide. The guide is available for download
> > from Epicweb in 3 parts, here is a link to the first part:
> https://epicweb.epicor.com/doc/Docs/EpicorUserExpCust_UserGuide_905700_Par
> > t1of3.pdf
> > Rick Bird
> > Rowmark, LLC.
> <mailto:vantage%40yahoogroups.com> , "Anon"
> > <jgiese@> wrote:
> > > Is there a way to add custom icons for menu items? I see the labels
> > custom 1-5 not sure if that's any indication this is possible.
