Custom MES Buttons Enabled Status
I am having the same problem, it is active but is greyed out. Also is there an easy way to distribute the customization to other MES stations.
Justin
--- In vantage@yahoogroups.com, "Jeff Rogers" <jeff.rogers@...> wrote:
> Brian - did you figure out how to do this? If so, please share!
> --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@> wrote:
> > Is there a way to make one of the customized MES buttons so that it
> > looks enabled? It has a slightly different style than the actually
> > enabled ones - its definitely clickable and and does what I want, but it
> > looks slightly greyed out.
> > How do I fix this? I tried playing with the EpiBinding property, and
> > tried to set the ButtonStyle to no avail (couldn't figure out what type
> > the property was).
> > Wisdom?
> > Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> > Picometrix
> > bspolarich@
> > <mailto:bspolarich@> ~ 734-864-5618 ~
> > www.advancedphotonix.com <http://www.advancedphotonix.com>
the property was).
Wisdom?
Picometrix
bspolarich@...
<mailto:bspolarich@...> ~ 734-864-5618 ~
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> the property was).
> Wisdom?
> Picometrix
> bspolarich@...
