Ken,
If you are printing via a check box, you should be able to set the code of a
button to check the box.
That should accomplish the same result. You may have to wait for the label
until you commit the record.
This may not be the final result you are looking for, but it might guide you
to the solution you are looking for.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Ken Williams
Sent: Thursday, December 27, 2007 6:22 PM
Subject: [Vantage] Custom Print Button
I have developed a BAM checkbox in the orderhed that when checked auto
prints a label. This works great, but it would work even better if I could
have a button that when pushed auto printed this same label. I've searched
high and low for such a modification but seem unable to find one that would
work.
Are any of you using a button to print a crystal form and if so, have any
recommendations?
Ken
Good luck,
Aaron Hoyt
Vantage Plastics
Ken Williams
work.
recommendations?
Ken
