Customer Blanket orders
It is under MRP....materials requirement planning
Manasa
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stan Chmura
Sent: Tuesday, February 19, 2013 8:36 AM
Subject: RE: [Vantage] Re: Customer Blanket orders
I neglected to mention that I purchased Epicor (formerly known as Vantage)
in 1999 without any enhanced modules and have not added any since. That
probably explains why I cannot find the Forecasts where I expected - in
Order or Inventory management. Is that a piece of either AMM or CRM?
This communication is intended only for use by the addressee(s) named herein
and may contain technical data as defined in the International Traffic In
Arms Regulations (ITAR) 22 CFR 120.10. or the Export Administration
Regulations. Export of this material is restricted cannot be exported to
foreign persons or foreign destination without prior written approval from
the U. S. Department of State or the US Department of Commerce.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
tracy.tmat
Sent: Tuesday, February 19, 2013 8:54 AM
Subject: [Vantage] Re: Customer Blanket orders
The majority of our customers order via blanket orders and we use Sales
Orders for most of them and just release them as Firm as we monitor dates /
schedules and need to easily see their demand against their schedule.
However, we do also use forecasts for some customers as this shows demand
when we run MRP whereas I don't believe MPS does.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> ,
"davidsawan2000" wrote:
> Hi,
> Have you looked into Forcasts? They allow you to enter Demand without a
Sales Order and will drive component demand.
> -David
> David Sawan
"stanchmura" wrote:
> > We are trying to improve our current process on how to handle customer
blanket orders. Deliveries may span a year or more. To be sure to order all
parts required for manufacturing, either as one purchase or supplier
blanket, we cut multiple jobs where some jobs will not be used for a year or
more. Jobs are only cut for firm releases. Once marked as firm, (even though
delivery may be several months away) jobs are cut and the time phased report
identifies the needs and parts are ordered.
> > Interested in any and all methods used to cover material requirement
needs to support customer blanket orders.
> > Thanks
We are trying to improve our current process on how to handle customer blanket orders. Deliveries may span a year or more. To be sure to order all parts required for manufacturing, either as one purchase or supplier blanket, we cut multiple jobs where some jobs will not be used for a year or more. Jobs are only cut for firm releases. Once marked as firm, (even though delivery may be several months away) jobs are cut and the time phased report identifies the needs and parts are ordered.
Interested in any and all methods used to cover material requirement needs to support customer blanket orders.
Hi,
Have you looked into Forcasts? They allow you to enter Demand without a Sales Order and will drive component demand.
-David
David Sawan
> Thanks
The majority of our customers order via blanket orders and we use Sales Orders for most of them and just release them as Firm as we monitor dates / schedules and need to easily see their demand against their schedule.
However, we do also use forecasts for some customers as this shows demand when we run MRP whereas I don't believe MPS does.
--- In vantage@yahoogroups.com, "davidsawan2000" <davidsawan@...> wrote:
> Hi,
> -David
> David Sawan
> > Thanks
tracy.tmat
> Hi,
> -David
> David Sawan
> > Thanks
Forecast entry can be found under Production Management \ Material Requirements Planning \ General Operations :)
> tracy.tmat
> > Hi,
> > -David
> > David Sawan
> > > Thanks
