Customer Contacts List Alphabetized
Just a heads up for folks converting from 4.0 to higher versions about customer contacts. I'm not sure where it happened but somewhere between 4.0 and 5.2 the list of contacts got sorted on name. It used to be that the top one listed was contact number 1 and they were in contact number order (order they were added). So you could count on contact number 1 being able to be used for special purposes, such as contact for annual customer survey. Not any more. The screen does not show which person is which contact number so it leaves people guessing who is number 1. This may well have been noted in the lists of changes between versions but it got overlooked is having some big effects on how we mail things. Surveys don't always go to the primary purchasing contact and I really did not want to add a VB form check box but might have to now.
So just in case this matters at your site - a small heads up.
-Todd Caughey
Harvey Vogel Mfg. Co.
