Customer Part VS Supplier Part
If you take your BAQ and make a simple dashboard out of it (maybe with added criteria inputs of customer code and 'starting with' part number criteria fields), that might do the trick for you.
Good way to get comfortable with BAQs, dashboards, etc., in general.(Practiced knowledge you can build on later for more comlex things.)
Hope it helps
Rob
--- On Fri, 11/14/08, jplehr <jlehr@...> wrote:
Subject: [Vantage] Re: Customer Part VS Supplier Part
Date: Friday, November 14, 2008, 10:28 AM
Rob... thanks. This has some nice potential. I am getting ready to
test it with my engineering group.
Question... now that I have set this as a BAQ Search option, which is
now available any time we perform a part search, is there a way to
setup a 'Start At' option? Currently the query is displaying 136
items. As this grows it could become an issue to run through each
one to find the one you need.
Thanks.
Jeff
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
wrote:
> Write a simple BAQ or dashboard search to aid engineering by
searching for the customer p/n associated with your p/n. (Your p/n is
what will appear in YOUR BOM.)
> --- On Thu, 11/13/08, jplehr <jlehr@...> wrote:
> From: jplehr <jlehr@...>
> To: vantage@yahoogroups .com
> Date: Thursday, November 13, 2008, 4:02 PM
> Mark, thanks. Let me throw this at you. I am aware of
using the
> Customer Part as you mention and I am ok up to that point. Now,
move
> to the Engineering Workbench. If I inventory the manufacturer part
> then I need to list that on my B.O.M. to pull inventory. Wearing
my
> engineering hat, how do I easily find the part when setting up my
> B.O.M.. The cross-reference process doesn't flow to engineering
and
> that is where I get stumped. Again, if I am working from my
Customer
> B.O.M., where they do not reference the manufacturer part (this may
> have originally been on a separate document, I would plug the
> Customer number in and hope to see any possible cross-reference.
> The Customer part works well in Sale Order Entry and Shipping. I
am
> looking for the missing link on the middle work.
> --- In vantage@yahoogroups .com, Mark Wagner <mjfw2003@ .> wrote:
> > Jeff, you can link the customer part number to your part master
> through the sales order process (i.e. when an order is entered and
a
> customer part number is entered it will automatically create the
> linke going forward)Â or through customer part under Order
> Management/Setup. You link the customer part to your part based on
> the customer ID so one customer part can be used for different
> internal part numbers. You can usually add the customer part
number
> in most queries to track things like inventory
> > --- On Thu, 11/13/08, jplehr <jlehr@> wrote:
> > From: jplehr <jlehr@>
> > Subject: [Vantage] Customer Part VS Supplier Part
> > Date: Thursday, November 13, 2008, 2:58 PM
> > Vantage 8.03.406
> > Anyone out there dealing with a Customer who supplies their part
> number
> > and then provides you with 3 or 4 Manufacturer part numbers? They
> then
> > supply the B.O.M. that calls out their number. What and how do
you
> > enter this into Vantage? How do you manage inventory? It is very
> > possible that one or all of these manufacturer part numbers
(items)
> can
> > be used for another Customer. How do you manage this scenario?
What
> > do you list on your internal B.O.M.? Is it easly referenced
within
> the
> > system?
> > Thanks.
> > Jeff
Vantage 8.03.406
Anyone out there dealing with a Customer who supplies their part number
and then provides you with 3 or 4 Manufacturer part numbers? They then
supply the B.O.M. that calls out their number. What and how do you
possible that one or all of these manufacturer part numbers (items) can
be used for another Customer. How do you manage this scenario? What
do you list on your internal B.O.M.? Is it easly referenced within the
system?
Thanks.
Jeff
Jeff, you can link the customer part number to your part master through the sales order process (i.e. when an order is entered and a customer part number is entered it will automatically create the linke going forward) or through customer part under Order Management/Setup. You link the customer part to your part based on the customer ID so one customer part can be used for different internal part numbers. You can usually add the customer part number in most queries to track things like inventory
Vantage 8.03.406
system?
Thanks.
Jeff
The only suggestion I can come up with would be alternate revisions with
the main revision using the customer supplied part and alternate
revisions each using the OEM parts involved.
Charlie Smith
2W Technologies LLC / Smith Business Services
Of jplehr
Sent: Thursday, November 13, 2008 2:58 PM
Vantage 8.03.406
system?
Thanks.
Jeff
Mark, thanks. Let me throw this at you. I am aware of using the
Customer Part as you mention and I am ok up to that point. Now, move
then I need to list that on my B.O.M. to pull inventory. Wearing my
B.O.M.. The cross-reference process doesn't flow to engineering and
that is where I get stumped. Again, if I am working from my Customer
The Customer part works well in Sale Order Entry and Shipping. I am
> Vantage 8.03.406
number
then
can
the
> system?
> Thanks.
> Jeff
How about setting your Part's Search Word with the Customer Part Number or a
fraction of it (8 character field). Then in Engineering WB you can search
for the Part via the Search Word.
Scott Litzau, MCP
Olympus Flag & Banner
Information Systems Manager
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
jplehr
Sent: Thursday, November 13, 2008 3:03 PM
> Vantage 8.03.406
number
then
can
the
> system?
> Thanks.
> Jeff
Use your own part numbers (top level & components in the BOMs). Associate the (potentially multiple) customer part numbers to each of yours through customer price lists.
Vantage 8.03.406
system?
Thanks.
Jeff
Write a simple BAQ or dashboard search to aid engineering by searching for the customer p/n associated with your p/n. (Your p/n is what will appear in YOUR BOM.)
> Vantage 8.03.406
number
then
can
the
> system?
> Thanks.
> Jeff
I've buried multiple customer part numbers in the second (third, fourth)
line of a part description. That way you can enter even a partial
customer part number in 'Where Description Contains' and it will find
your part.
Greg
Of Scott Litzau
Sent: Thursday, November 13, 2008 3:09 PM
Subject: RE: [Vantage] Re: Customer Part VS Supplier Part
or a
search
Scott Litzau, MCP
scott.litzau@... <mailto:scott.litzau%40olympus-flag.com>
P: 414-365-9732
F: 414-355-1931
Behalf Of
jplehr
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Mark
> Vantage 8.03.406
number
then
can
the
> system?
> Thanks.
> Jeff
have
and
<http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
Thanks.
Jeff
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
using the
move
my
and
Customer
am
a
number
> > Vantage 8.03.406
> number
> then
you
(items)
> can
What
within
> the
> > system?
> > Thanks.
> > Jeff
Thanks to everyone who provided feedback. I think all were valid
ideas. I actually to the BAQ route and actually figured out how to
setup and Advanced Search and answered my own question to Rob. The
buy in was huge, so this was a huge win. This issue has been around
for a while and resurfaces every couple of months. Thanks again.
Jeff
--- In vantage@yahoogroups.com, "jplehr" <jlehr@...> wrote:
> Vantage 8.03.406
number
then
can
What
the
> system?
> Thanks.
> Jeff
