Bingo - I'm shipping from manufacturing hence the field you mention will be zero. Do you know the method for ship from manufacturing?
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> That mehtod requires that your ShipDtl.DispInvQty > 0
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Thu, Aug 16, 2012 at 10:26 AM, spmyers7582 <smyers@...> wrote:
> > OK, simply using the methodinfo and invoke, nothing happens.
> > Should I be replacing New Object with something, or should something be
> > placed in the parenthesis etc?
> > thanks.
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > Not sure what you mean, when you Invoke it should launchthe Select Serial
> > > NUmber form... not sure why you need the SNView
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Thu, Aug 16, 2012 at 10:09 AM, spmyers7582 <smyers@> wrote:
> > > > Apolgies, I'm lost here.
> > > > We've already invoked with:
> > > > mi.Invoke(oTrans, New Object() {})
> > > > How do i now move to an EpiDataView of SNSView?
> > > > Thanks!
> > > > > Just Invoke the method..
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > On Thu, Aug 16, 2012 at 9:42 AM, spmyers7582 <smyers@> wrote:
> > > > > > I sorted the conversion, but am now wondering how this now
> > integrates
> > > > into
> > > > > > the code you supplied the other day.
> > > > > > I put the mi object to a message string and it output "void:
> > > > > > GetSerialNumbers()"
> > > > > > The final result I'm hoping for here is the select serial numbers
> > > > form...
> > > > > > thanks!
> > > > > > > *Warning this is mostly fun and games, but I am giving you the
> > > > answer,
> > > > > > so I
> > > > > > > get to have a bit of fun fair enough?*
> > > > > > > The code I wrote is in .NET.....
> > > > > > > .NET is a platform which hosts a series of languages such as VB,
> > C#,
> > > > C++,
> > > > > > > F# etc..
> > > > > > > The code I wrote is C#, there are a lot of translators on the web
> > > > that a
> > > > > > > Google search would get for you go to the following URL
> > > > > > > http://goo.gl/vffYI
> > > > > > > Click the Second Link that one will Translate the code I provided
> > > > :-), if
> > > > > > > you'd like to get past the sarcasm you can just click directly to
> > > > > > > http://converter.telerik.com/
> > > > > > > Sorry bud, just having a bit of fun its been a long day already,
> > if
> > > > you
> > > > > > > have any other questions let me know
> > > > > > > Thanks!
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > On Thu, Aug 16, 2012 at 8:59 AM, spmyers7582 <smyers@> wrote:
> > > > > > > > Thanks for the code; however, I'm having trouble converting
> > this to
> > > > > > .NET:
> > > > > > > > Imports System.Reflection
> > > > > > > > Dim mi As MethodInfo =
> > TypeOf(Epicor.Mfg.UI.App.CustShipEntry.Transaction).GetMethod("getSerialNumbers",
> > > > > > > > BindingFlags.NonPublic Or BindingFlags.Instance)Is MethodInfo
> > > > > > > > The compiling error is:
> > > > > > > > Error: BC30456 - line 177 (1220) - 'GetMethod' is not a member
> > of
> > > > > > > > 'Epicor.Mfg.UI.App.CustShipEntry.Transaction'.
> > > > > > > > Can you help please?
> > > > > > > > thanks.
> > > > > > > > > All right the code I gave you earlier was for 8.03
> > > > > > > > > Try this
> > > > > > > > > using System.Reflection;
> > > > > > > > > MethodInfo mi =
> > typeof(Epicor.Mfg.UI.App.CustShipEntry.Transasction).GetMethod("getSerialNumbers",
> > > > > > > > > BindingFlags.NonPublic | BindingFlags.Instance);
> > > > > > > > > mi.Invoke(oTrans, new object[] { });
> > > > > > > > > *Jose C Gomez*
> > > > > > > > > *Software Engineer*
> > > > > > > > > E: jose@
> > > > > > > > > On Thu, Aug 16, 2012 at 8:03 AM, spmyers7582 <smyers@>
> > wrote:
> > > > > > > > > > Epicor 9.05.607B
> > > > > > > > > > SNS is a view available in Customer Shipment Tracker (which
> > > > > > contains
> > > > > > > > the
> > > > > > > > > > fields 'ProcessToken' and 'genericToken1'), however this
> > > > doesn't
> > > > > > reveal
> > > > > > > > > > itself in customer shipment entry.
> > > > > > > > > > Thanks
> > > > > > > > > > > What version are you on?
> > > > > > > > > > > *Jose C Gomez*
> > > > > > > > > > > *Software Engineer*
> > > > > > > > > > > E: jose@
> > > > > > > > > > > On Thu, Aug 16, 2012 at 4:37 AM, spmyers7582 <smyers@>
> > > > wrote:
> > > > > > > > > > > > I've been given the following advice:
> > > > > > > > > > > > 'The SNSView is a Serial Number view which is
> > available in
> > > > > > > > CustShip,
> > > > > > > > > > just
> > > > > > > > > > > > look at it in the wizard.'
> > > > > > > > > > > > However, I can't find any reference to this dataView
> > > > anywhere.
> > > > > > > > > > > > Can anyone help please?
> > > > > > > > > > > > Thanks.
> > > > > > > > > > > [Non-text portions of this message have been removed]
