Cool deal, I had to run a conversion a few weeks back, but they were all not working then. This seems to be an isolated one. I will try the conversion again if that doesn't work I contact support. Thank you for your help with this. Much appreciated.
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Yes, Run conversion 9527
> If it happens again (it did for us), Support can toss you a one-off perm
> fix. Reference my call# with them if you need to: 2249311ESC
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> bryandavis1980
> Sent: Wednesday, December 05, 2012 1:43 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Customer Tracker Error
> We have one customer in our list customers that gives us the following error
> when selected. As far as I can tell, the rest are working fine. Stack trace
> below. Anybody else ran into this issue before?
> Error Detail
> value does not match the mask
> Stack Trace
> at Infragistics.Win.UltraWinMaskedEdit.InputCharBase.set_Char(Char value)
> at Infragistics.Win.UltraWinMaskedEdit.NumberSection.SetText(String text)
> at Infragistics.Win.EditorWithMask.SetDoubleValue(SectionsCollection
> sections, Double val, MaskInfo maskInfo)
> at Infragistics.Win.EditorWithMask.SetDataValue(SectionsCollection sections,
> Type dataType, Object val, MaskInfo maskInfo)
> at Infragistics.Win.UltraWinMaskedEdit.EditInfo.SetValue(Object val)
> at Infragistics.Win.UltraWinMaskedEdit.EditInfo.set_Value(Object value)
> at Infragistics.Win.EditorWithMask.set_Value(Object value)
> at Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value(Object
> value)
> at
> Epicor.Mfg.UI.FrameWork.EpiNumericEditor.oDataView_EpiViewNotification(EpiDa
> taView view, EpiNotifyArgs ar)
> at Epicor.Mfg.UI.FrameWork.EpiViewNotification.Invoke(EpiDataView view,
> EpiNotifyArgs args)
> at Epicor.Mfg.UI.FrameWork.EpiDataView.Notify(EpiNotifyArgs args)
> at Epicor.Mfg.UI.App.CustomerTracker.Transaction.GetCustomerData(String
> custNum)
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2221 / Virus Database: 2634/5438 - Release Date: 12/05/12
