Please clive.1972 if you found any help on this issue let me know because I am also looking forward to see any response to your your question. I am trying to add a search button for suppliers in a Dashboard and I was told to add a Dashboard Browse.
Thank you in advance for any help or comment
PP
PP
--- In vantage@yahoogroups.com, "clive.1972" <clive.1972@...> wrote:
> It's all starting to become clearer :)
> I now understand that I need to create a some code using the Event
> Wizard to call the Customer Search program. One problem here is how
> the heck do you find out what the Customer Search program is called
> as I'm not aware of anywhere that lists all of the available ones ?.
> And then more code needs to be writen to pass the results of the
> search to a field in orderhed and then I create a Foreign Key View
> that allows me to reference anything else I want to pull from the
> customer table ?.
> --- In vantage@yahoogroups.com, "clive.1972" <clive.1972@> wrote:
> > Hi Rob,
> > Thanks for pointing me in the direction of the Events Wizard, I'm
> > poor at coding but can bumble through simple tasks, I'll examine
> > the 'Epicor Tools User Guide' on this topic.
> > On my new sheet I need to have the button launch a standard search
> > against Customers, nothing fancy here. And once the customer has
> been
> > selected I need two text boxes to be populated with the customer
> > number and their name. This is customer data which is not related
> to
> > the Sold To, Bill To or Ship To.
> > Thanks.
> > --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> > wrote:
> > > Sorry Clive - Not Form Event Wizard. Use Events Wizard.
> > > (LOOOOOOOONG night.)
> > > Rob
> > > --- On Thu, 12/4/08, Robert Brown <robertb_versa@> wrote:
> > > From: Robert Brown <robertb_versa@>
> > > Subject: Re: [Vantage] Customisation: How to add a search button
> to
> > a new sheet ?
> > > To: vantage@yahoogroups.com
> > > Date: Thursday, December 4, 2008, 5:52 AM
> > > No shortcuts Clive.
> > > After you've added your button, use the form event wizard to use
> a
> > mouseclick down action on your custom button to act as the even
> > trigger for your subroutine.
> > > What code you put inside? Who knows? (You don't get specific
> enough
> > about what you are trying to do.)
> > > As for the search, why wouldn't the native appliation search work
> > for you (with a BAQ search specific to your needs)?
> > > (I know I must be misunderstanding something here.)
> > > Rob
> > > --- On Thu, 12/4/08, clive.1972 <clive.1972@yahoo. com> wrote:
> > > From: clive.1972 <clive.1972@yahoo. com>
> > > Subject: [Vantage] Customisation: How to add a search button to a
> > new sheet ?
> > > To: vantage@yahoogroups .com
> > > Date: Thursday, December 4, 2008, 4:35 AM
> > > I'm currently working on my first customisation, adding a new
> sheet
> > to
> > > the Quote Entry form which will store some custom data in the
> table
> > > quotehed. I also need to add a search button to the new sheet,
> > which
> > > will link to the customer table, and populate a couple of text
> > boxes
> > > with a customers data.
> > > The problem is that I have no idea how on earth to setup a button
> > I've
> > > added to my new sheet as a search button, and then get the search
> > > result to populate the other boxes on the sheet ?. I'm not great
> > with
> > > code so I'm keeping my fingers crossed that there's a simple
> > solution ?.
> > > Thanks.
> > > p.s. I also have this as a support call with Epicor so if I get
> any
> > > advice from them on how to achieve this I'll post the results
> here
> > as
> > > well.
