Suggestion then: Stick a messagebox.show(your msg) within every subroutine and function you have ('your msg' indicating which sub or function is invoked).
That'll make any inadvertant looping obvious.
Rob
Sent: Monday, June 22, 2009 4:04:09 AM
Subject: [Vantage] Re: Customisation on Order Entry causes a five minute order load time
I'd love to post the code, however, I'm not in a position to do so :(
I'll stumble along blindly for a while and see what happens...
Rob
--- In vantage@yahoogroups .com, robertb_versa@ ... wrote:
> If your company authored the customization, time to review & reoptimize.
> Sounds like you may have setup of multiple event triggers that are tripping each other into a long circular loop.
> Post your code. Someone here might see something obvious.
> Get ready for a battle if you try to drop support. It's their cash cow & will fight.
> Be firm though and you'll be alright. (They'll take you back if you change your mind in the future no matter what they threaten.. It's nearly pure profit for them.)
> Rob Brown
> --- Original Message ---
> From:"clive. 1972" <clive.1972@ ...>
> Sent:Thu 6/18/09 9:12 am
> To:vantage@yahoogroups .com
> Subj:[Vantage] Re: Customisation on Order Entry causes a five minute order load time
> Oh no, it's not an Epicor created customisation, and as usual once they're aware of this there's no support from them.
> We have to renew in September, and this time I genuinely think that we'll be dropping the maintenance. ..
> --- In vantage@yahoogroups .com, robertb_versa@ wrote:
> > Epicor wrote the customization (for fee) & it performs like this?
> > Escalate it (threaten dropping maintenance if necessary). That is unacceptable!
> > Rob Brown
> > From:"clive. 1972" <clive.1972@ >
> > Sent:Thu 6/18/09 5:39 am
> > I enabled 'Tracing' in Vantage to see if this would help me diagnose this at all, unfortunately it hasn't but the text below repeats itself every 30 seconds for around 4 and a half minutes whilst the sales order loads...
> > <tracePacket>
> > <businessObject> Epicor.Mfg. BO.ReportMonitor </businessObject >
> > <methodName> GetRowsKeepIdleT ime</methodName>
> > <returnType> Epicor.Mfg. BO.ReportMonitor DataSet</ returnType>
> > <localTime>18/ 06/2009 10:22:33:1705002 AM</localTime>
> > <executionTime> 0</executionTime >
> > <parameters>
> > <parameter name='whereClauseSy sRptLst' type='System. String' ><![CDATA[AutoActio n <> '' AND WorkStationID ='MSL026 0']]></parameter>
> > <parameter name='pageSize' type='System. Int32' ><![CDATA[0] ]></parameter>
> > <parameter name='absolutePage' type='System. Int32' ><![CDATA[0] ]></parameter>
> > <parameter name='morePages' type='System. Boolean' ><![CDATA[]] ></parameter>
> > </parameters>
> > </tracePacket>
> > ... I'll log a support call with Epicor about this, however, as this is a customisation they'll say that this needs to go to their consulting team and will be chargeable (Epicor UK allways seem to do this and wash their hands of customisations like this).
> > --- In vantage@yahoogroups .com, "clive.1972" <clive.1972@ > wrote:
> > > We've recently started running a customisation against Order Entry (in Vantage 8.03.406A) that our parent company who also use Vantage have requested we use. However, on a small selection of computers this new customisation causes a sales order to take approx five minutes to load ! (from the point where you type in an order number and hit tab on your keyboard).
> > > All of our computers are running Windows XP, with either SP2 or 3, and Sophos AV reports that they are virus free. All dotNet updates are applied, up to dotNET 3.5 SP2, as are MDAC etc.
> > > The only way I've been able to cure this problem is by wiping the computer and installing a fresh Windows XP, which even with imaging software takes too long.
> > > Are there any other libraries / runtimes etc that I need to update ?. There must be a reason why this is happening, but I just can't find out why ?.
> > > Thanks.
