Hello,
We’ve come across an issue with Issue Material where, when searching for Lots against a Part/Bin combo, the information that appears in the Search Results is not entirely accurate.
The info at fault is the Qty On Hand. If a Lot is across several Bins, it will take the Qty that exists in what seem to be the first Bin alphabetically, as opposed to the Bin being searched against.
I am hoping there is some way to modify the search to be accurate. Although it only displays the Lots that exist in that Bin, something about the search means it is not actually identifying the appropriate PartBin record for Qty (probably due to it searching Primarily on PartLot.)
I have tried poking around in App Studio and looking at the appropriate event (LotNum_Search) but I am not having much joy. I tried changing it to a BAQ Search but that does not seem to work in these circumstances (no search button is available when it launches.)
What would be the best way to modify the search?
Cole
