Wizard → Reference Adapter/BL Assemblies
Launch Wizard → Get Adapters
Choose PO Adapter
Close
Add this code and a textbox called txtShipViaCode.
private EpiBaseAdapter oTrans_invAdapter;
this.oTrans_invAdapter = ((EpiBaseAdapter)(this.csm.TransAdaptersHT["oTrans_invAdapter"]));
this.oTrans_invAdapter.AfterAdapterMethod += new AfterAdapterMethod(this.oTrans_invAdapter_AfterAdapterMethod);
// Begin Custom Code Disposal
// End Custom Code Disposal
this.oTrans_invAdapter.AfterAdapterMethod -= new AfterAdapterMethod(this.oTrans_invAdapter_AfterAdapterMethod);
this.oTrans_invAdapter = null;
private void oTrans_invAdapter_AfterAdapterMethod(object sender, AfterAdapterMethodArgs args)
// ** args.MethodName **
// ** Add Event Handler Code **
// ** Use MessageBox to find adapter method name
// EpiMessageBox.Show(args.MethodName)
switch (args.MethodName)
case "ChangeRefPONum":
FillSearchFromPOAdapter();
break;
private void FillSearchFromPOAdapter()
EpiDataView edvAPInvHed = ((EpiDataView)(this.oTrans.EpiDataViews["APInvHed"]));
System.Data.DataRow edvAPInvHedRow = edvAPInvHed.CurrentDataRow;
bool recSelected;
string whereClause = "PONum = '" + edvAPInvHedRow["REFPONum"] + "'";
System.Data.DataSet dsPOAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "POAdapter", out recSelected, false, whereClause);
if (recSelected)
System.Data.DataRow adapterRow = dsPOAdapter.Tables[0].Rows[0];
//MessageBox.Show(adapterRow["ShipViaCode"].ToString());
txtShipViaCode.Text = adapterRow["ShipViaCode"].ToString();
