Customization Button need to have report attached pull in Sales Orde
We have a button (added through customization) that can print a crystal
report to a printer without the viewer. We would like to send this
report a parameter, which at this point we can only send it a hard coded
value in VB.NET. All works well, except what we need is to grab a value
from the sales order text box (orderhed.order.num) on the sales order
Entry form and place that value where we have the value hard coded in.
We would appreciate any suggestions to get the sales order number that
is currently being worked on to the report?
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
WWW: http://www.aceprecision.com
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
