Customization Button need to have report attached pull in Sales Orde
what does your code look like to be able to run a crystal report? I
have never been able to do that yet via a customization. i have
always just had to set up a BAM and use the auto print feature. Is
there a way that i can run the report from .net code?
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> Hi Paul,
> This is a function we use to get the quote number for Crystal Viewer:
> private function GetQuoteNum() as string
> ' dimension object variables
> ' dimension variables
> Dim sQuoteNum as string = ""
> ' get the quote number from the screen
> Try
> If edvQuoteHed.dataView(edvQuoteHed.Row)("QuoteNum") <> 0 Then
> tmpQuoteNum =
> sQuoteNum = ctype(tmpQuoteNum,String)
> Else
> ' if no quote is on the screen then display a message and return
> false
> MessageBox.Show("Please select a quote before trying to
> print.")
> end if
> Catch ex as Exception
> End Try
> return sQuoteNum
> end function
> This is how we setup the record selection formula (just replace the
> 'xxxx' with your company code):
> sRecSel = "{QuoteHed.Company} = 'xxxx' and {QuoteHed.QuoteNum} = " +
> sQuoteNum
> Load the report
> Set the database logon
> Then set the record selection formula (Just replace oRpt. with your
> report object variable):
> oRpt.RecordSelectionFormula = sRecSel
> hth
> Linda Lowney
> Pride Signs Ltd
> 280 Holiday Inn Drive
> Cambridge, ON N3C 1Z4
> Ph: 519-220-0505 x258
> Fx: 519-220-0606
Hi Paul,
Try
tmpQuoteNum =
Else
false
print.")
end if
End Try
return sQuoteNum
end function
sQuoteNum
Load the report
hth
Linda Lowney
Pride Signs Ltd
Fx: 519-220-0606
