Customization - Combo Box
Youre talking about an ultragrid?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Michelle de la Vega
Sent: Tuesday, December 08, 2009 12:43 PM
Subject: RE: [Vantage] Customization - Combo Box
That worked! Thanks.
Ok, now I have another similar issue. In order entry, when adding a misc
charge on the line, the drop down for the misc charge is too small. I
tried to do the same thing, but instead of it being a combo box it is a
"grid".
Any thoughts on that?
Thanks again for your help!
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CA780C.680948A0
<mailto:image001.jpg%4001CA780C.680948A0> ]
Behalf Of Rob Bucek
Sent: Tuesday, December 08, 2009 11:04 AM
Under properties, try autowidth = true and autowidthoption = control
width
Rob Bucek
FAX: (715)284-4084
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Sent: Tuesday, December 08, 2009 9:26 AM
Subject: [Vantage] Customization - Combo Box
I have created a new tab on the sales order and one of the UD fields I
have assigned to a combo box. However when you click the drop down arrow
to see the choices in the list, the drop down is narrow and you can't
see the whole word. Does anyone know how to make the drop down wider?
Any help would be greatly appreciated.
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@...0B840
<mailto:image001.jpg%4001CA77F0.DAC0B840>
<mailto:image001.jpg%4001CA77F0.DAC0B840> ]
I have created a new tab on the sales order and one of the UD fields I have assigned to a combo box. However when you click the drop down arrow to see the choices in the list, the drop down is narrow and you can't see the whole word. Does anyone know how to make the drop down wider?
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@...0B840]
width
Rob Bucek
FAX: (715)284-4084
Michelle de la Vega
Cold Jet, LLC
USA
You may if that doesn't work, need to set col1manualwidth etc to a
certain value, though I haven't had to go that far yet.
Rob Bucek
FAX: (715)284-4084
Michelle de la Vega
Cold Jet, LLC
USA
Ok, now I have another similar issue. In order entry, when adding a misc charge on the line, the drop down for the misc charge is too small. I tried to do the same thing, but instead of it being a combo box it is a "grid".
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@01CA780C.680948A0]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
width
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@...0B840<mailto:image001.jpg%4001CA77F0.DAC0B840>
