I know someone has probably done this, but I have been racking my brains and have not gotten any code to work yet.
I have an epiRetrieverCombo for UD03 on the page, and only want somebody to be able to set the value if the Product Code of the part is one of a few entries. I am assuming I will have to use the code to set Enabled to true. I saw where you can use the Rule Wizard to disable a field, but that did not work if you are looking for a Not Contains or other similar rule. Otherwise I would have to put every ProdCode other than the ones I do want it enabled on.
Any guidance? Thanks!
