Need a bit more details. How did you attempt to use it? What errors did you get? Did you change the references to refer to the names you gave things? It was a quick cut and paste as I mentioned and does need adjustment to fit your needs but it is code I have used quite a few times.
Jim K.
Jim K.
--- In vantage@yahoogroups.com, "przemyslawhinz" <przemyslawhinz@...> wrote:
> Did you try this code?
> It doesn't work in my system or I don,t know how to use it :-/
> Przemek
> --- In vantage@yahoogroups.com, "jckinneman" <jckinneman@> wrote:
> > From a copy paste so may have to do some syntax fixing.
> > Put this in your initialization code making the appropriate changes, also need
> > this in the using area
> > using Infragistics.Win.UltraWinToolbars;
> > // add a new menu choice to the actions menu
> > Infragistics.Win.UltraWinToolbars.PopupMenuTool PopMenu;
> > Infragistics.Win.UltraWinToolbars.ButtonTool custButton = new Infragistics.Win.UltraWinToolbars.ButtonTool("NewReport");
> > custButton.SharedProps.Caption = "My Report";
> > if (baseToolbarsManager.Tools.Exists("NewReport) == false)
> > baseToolbarsManager.Tools.Add(custButton);
> > baseToolbarsManager.Tools["ActionsMenu"].SharedProps.Enabled = true;
> > PopMenu = (Infragistics.Win.UltraWinToolbars.PopupMenuTool)
> > baseToolbarsManager.Tools["ActionsMenu"];
> > PopMenu.Tools.AddRange(new Infragistics.Win.UltraWinToolbars.ToolBase[]{custButton});
> > Image extProcImage = EpiUIImages.GetImage("ExternalProcess");
> > Infragistics.Win.Appearance extProcApp = new Infragistics.Win.Appearance();
> > extProcApp.Image = extProcImage;
> > baseToolbarsManager.Tools["NewReport"].SharedProps.AppearancesLarge.Appearance = extProcApp;
> > baseToolbarsManager.Tools["NewReport"].SharedProps.AppearancesSmall.Appearance = extProcApp;
> > Then using the wizards add a toolclick event and then call your report from the
> > toolclick event. Use a switch to find your report
> > switch(args.Tool.Key.ToString())
> > case "NewReport":
> > // call report
> > break;
> > There is a file I uploaded in the Epicor 9 section that shows how to call the
> > report itself.
> > En>compass Solutions Inc.
> > Tel 336.298.1296 (Google Voice)
> > Fax 336.217.7983
> > E-mail jimki@
> > www.encompass-inc.com
> > --- In vantage@yahoogroups.com, "przemyslawhinz" <przemyslawhinz@> wrote:
> > > Hi all,
> > > if anyone knows how I can add a custom report (made in the CR) to the Actions menu?
> > > In program Opportunity/Quote in Actions menu is option to print a form. I need similar functionality but in Customer Shipment Entry or Issue Material.
> > > best ragards
> > > Przemek
